Thread: Home forging
    You can cast parts that can't reasonably be machined, that's a great reason to melt aluminium and other metals, I have a propane fired furnace rated for 2gk of Iron, although it sees more lead/antimony than iron or aluminium.
    If it's for parts you are machining you may be better with bought stock where that works for form of the parts, you will not match the tensile strength of commercially manufactured bar or plate stock with home cast and without testing facilities you will not know the exact composition of what you're throwing in the pot or pouring out of it.
    You should only need a blower for mains natural gas, none of the burners on Ron Reill's site required blowers and some of the guys involved in propane burner development got furnaces running at temperatures where UV protection for users became necessary.
    The main thing is to enjoy and learn but don't expect to end up spending less ;-)
    Last edited by magicniner; 03-04-2016 at 07:55 PM. Reason: spelling and punctuation corrections
    It may be worth thinking about the type of Aluminium you want to forge. As an ex-biker I know forged pistons are softer and expand more than cast pistons. There is less silicon (if any) in a forged piston whereas it is used in cast pistons to reduce expansion - 9-17% depending on application. If I were to reach for some scrap to heat I think I'd look for some rolled plate or extruded bar before I reach for an old casting. The silicon limits the plasticity/elasticity you need in a forging - I think you may be looking at cracking as a problem if there's too much Silicon. I don't know a way of reducing Silicon content in a smelt other than dilution.
    There's nothing to stop you from casting some melted extrusions like 6082 to get the shape ingot you can control, and then hammering the heck out of it. I'd love to see what you decide to make though!
    D
  1. Home is where the part is?
    Last Post: 15-07-2013, 09:58 AM
  2. WANTED: home built cnc
    By japcarmaniac in forum Items Wanted
    Last Post: 24-04-2013, 02:35 AM
  3. value of home switches
    By engineshed in forum General Electronics
    Last Post: 04-04-2012, 12:01 AM
  4. Home switching
    By Vard in forum General Electronics
    Last Post: 14-03-2012, 08:32 PM
  5. Home made CNC for 50 €
    By Lee Roberts in forum Gantry/Router Machines & Building
    Last Post: 26-05-2009, 08:12 PM
