    After a little experiment, I settled on sticking it on the film on the underside too. Worked great! Stuck strong. Easy to remove from MDF & aluminium. I used the Dial brand one from B&Q..
    I tried the 2mm cutter on the settings above on some 2.2mm holes, and all seemed ok. I used a steeper angle helix this time and the chips certainly do fly like that!
    I just did 1 pass.. am I right in thinking that due to this, the accuracy isn't great?
    eg. some holes I can fit a 2.2mm drill bit in nicely.. others are too tight..
    If I wanted it more accurate and repeatable, I'd have to pocket the holes at Ø2mm and then do a contour finish pass to enlarge to exactly 2.2mm?
    Generally yes, a roughing pass leaving 0.1mm or so then a finish pass is best, i find it works well.
  1. Aluminium cutting
    By Bush Flyer in forum Metalwork Discussion
    Last Post: 13-05-2016, 09:57 AM
  2. Save my sanity - 1050 grade aluminium
    By Isaac in forum Metal Finishing Techniques
    Last Post: 03-06-2014, 01:45 AM
  3. Any tips for deep slots/profiling in aluminium?
    By m_c in forum Metalwork Discussion
    Last Post: 18-04-2014, 12:00 AM
  4. Best Tips for Cutting 6082 Aluminium (CNC Lathe)
    By fidia in forum Metal Finishing Techniques
    Last Post: 29-12-2013, 07:09 PM
  5. RFQ: RFQ: Need some thin aluminium cutting
    By stewpid22 in forum Projects, Jobs & Requests
    Last Post: 21-09-2012, 01:11 PM
