Thread: Got a job - how to do it ? :)
Brass is my favourite material. Perfect i would say. Drills, machines,taps like a charm.
Probably 60 degree V cutter will do it best. Now the great thing is that you could grind away the point, measure it and enter its tip size at the program. Voilaa, no need for tool change and avoiding complications. So instead of scratching the point on a V carve path, you will finish the flat space much faster.
Especially if you CAM could not combine properly V carve paths with pocket paths later. Which by the way is not so simple at all as it seems if the result must be perfect. Impossible by not electronically setting the tool height by probing in mach 3. Even then... The problem being not knowing the exact sharp V cutter tip size. If using non brand cutter, especially.
My advice- simplicity. Roughen if possible with bigger tool. Use flat tip V cutter and finish directly. No complications, if a bit more time. Bonus- no tip breakage, faster, simpler.
07-04-2016 #2
I see the idea of grinding the tip on a v-bit but i need it to give me sharp internal corners, Sheetcam has a sharpen feature that raises the Z as it approaches a corner and the lowers it again, i think that will work.
07-04-2016 #3
Wouldn't the required tip size will be determined by how sharp the internal corners need to be at the upper surface of the part?
07-04-2016 #4
07-04-2016 #5
That is geometrically incorrect, if you were right a 15 degree cutter with a 3mm flat will generate really sharp corners?
The size of the flat at the tip of the cutter determines it's effective minimum diameter and directly dictates how sharp an internal corner you can generate with it.
- Nick
09-04-2016 #6
07-04-2016 #7
Yes, it's all supposition at present.
I did look at some scrap blocks today and it seems anything around what appears to be from a 0.2 to 0.4mm radius is a 'sharp' corner for this stuff so a flat tipped v-bit with a 0.1 or 0.2 tip might work, might even be worth trying some of the 3mm engraving cutters i was gifted on it.
