    HI All,
    I am currently looking for a quality parametric cad/cam software and hoping someone could give me some advice as there are so many options.
    i am a self employed joinery of 10 years and in the past year have started to get into cnc and bought a scm router with xilog plus, i am still fairly new but mostly manifacture cabinets so i am looking at the following softwares
    xcab...... seems limited to square boxes but has good cam/hardware inventory
    Poly board ..... less expensive than xcab but seems to do alot more but noone seems to use it
    cabinet parts pro ...... i have looked at the least as seemed very american and mostly aimed at inframe designs
    if anyone has experience with parametric softwares and know any others available or which is best i would be over the moon with any advise
    many thanks
    dean
    Assuming you spent some decent money on the SCM, I recommend that you also spend some money on a GOOD cabinet package.
    The software makes all the difference in the world regarding your productivity. I see way too many people not utilizing their machines because they don't have the right software. Mainly because they don't know what software can do for them.
    I'm not familiar with XCAB, as it seems to be aimed at you market. Looks like your interested in doing much more than square boxes though?
    If that's the case, you won't really find much out there that automates the process of building custom furniture items.
    The one that comes to mind is Top Solid, but it can be very expensive.
    If you're a one man shop, then look at something like Fusion 360.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    Thanks for the reply Ger21 , yes i am a one man with 1 employee shop, but would like a good software to speed things up and like the look of parametric stuff as im working in 2d at the moment which is slow and alot of customers dont get 2d drawings where parametric softwares seem to have 3d visuals
    im liking the look of polyboard from wooddesigner.org but i cant seem to see anyone using it and wondering if there is a reason for this ??
    xcab with nesting and 3 days minimum training works out at £5,500 ish , and im wondering will i get moneys worth from switching from 2d
    If you need 3D for customers, than it's going to be costly for a high end package.
    I use a custom AutoCAD macro to export my parts, and nest them in AlphaCAM. I just enter cabinet sizes, and a few minutes later I'm cutting.
    I have no experience with any of the programs used outside of the US.
    Cabinet Vision is big here. I've never been a fan after a bad experience with them many years ago.
    I'd recommend getting hold of trial versions, even if you need to "Rent" them for a while before purchasing. If they won't give you that option, I'd look elsewhere.
    And be leery of demos from salesmen.
    Gerry
  5. The Following User Says Thank You to Ger21 For This Useful Post:
  6. #5
    I would as above look at Fusion360 easy to convert 2d to 3d something to show the customers free trial period, free for hobby use and good price on licencing if you decide its OK for your business, its something thats developing fast and will grow where I suspect many packages are stagnant and offer less for more. It costs nothing to take a look, with no cad cam experience I was producing basic work within a weekend and continue to learn with each use as an ex bricklayer/ general builder with lots of joinery experience it would be my choice if I were to design bespoke cabinets now, and easy to change dimensions as required or parametric as people say.
  7. #6
    Hi Dean
    I can highly recommend Fusion 360 from Autodesk. We are a dedicated wooden furniture workshop and we run entirely off of Fusion and Xilog Plus.
    Fusion's CNC programming is extensive and we have developed a post processor to communicate flawlessly with SCM CNC machines. Please get in touch if you would be interested in this product or any help with CNC programming for wood. A lot of resources out there are very metal fabrication focused.
    Wishing you all the best in these trying times
    Michael
  8. #7
    Quote Originally Posted by michaeletsmith View Post
    Hi Dean
    Michael
    Hi Michael,
    post processor sounds very interesting if i could give that a try, i have used fusion a little but definitely something id like to do more with.
    my email is teestechjoinery@gmail if possible to shoot me a message there please
    Many Thanks
    Dean
  9. #8
    A thread from the distant past resurrected.I have been using Freecad and I like it in spite of the non intuitive way of working and it pleases me to know that there won't be a switch to a subscription model.Any and all components can be designed using the parameters and updated accordingly and then the assembly module can be used to assemble them.The fun part comes when you use the recursive updating feature and the assembly changes on screen.Since I use the inbuilt LinuxCNC post processor to create cutting files it also means that clicking on the update button sees the toolpath modified just about instantly.I haven't yet found a nesting module and there may well be such a thing under development.
  10. #9
    Hi Michael
    Was really interested in reading your comments, we have recently acquired a SCM Tech 95 and now looking to drag it into this century. Machines been pretty flawless but original operators coded everything manually onto the controller, its painful. I've got something like 4,000 PGM files that I need to convert, catalog and need to bring this together with some reasonably priced software to help. People often mention Xilog Plus as a method of importing PGM files so they can be edited and saved? I've also looked at Mosaic software for cabinet making, any thoughts? Can you advise where I may be able to get Xilog? Regards, Tony.
  11. The Following User Says Thank You to Asdeane For This Useful Post:
  1. What software can do this ?
    By Kammo1 in forum Computer Software
    Last Post: 06-04-2026, 10:58 AM
  2. software
    By rainboweyes in forum Computer Software
    Last Post: 09-02-2013, 11:59 AM
  3. Cambium Code Web Tools – Parametric G-code Generation
    By CambiumMachines in forum Manufacturer News
    Last Post: 09-01-2013, 04:56 AM
  4. Replies: 2
  5. parametric equations
    By vboperator in forum Machine Discussion
    Last Post: 25-04-2010, 02:42 PM
