Thread: Simple Current Limiter (LM317)
Since you can make a two terminal current source with a LM317 you could just put two in series to extend the voltage range.
(See Irving's example here:http://www.mycncuk.com/forums/attach...5&d=1247335598)
Be careful you don't exceed the chips power rating (i.e. check data sheet for maximum simultaneous voltage drop & current)
[edit] just saw this
You really need to put a separate current limiter on each phase in a unipolar design else it'll run out of puffI am going to be running 3 stepper motors in unipolor, so I am going to need 2 LM317HV's per stepper motor.Last edited by BillTodd; 12-07-2009 at 02:58 PM.
12-07-2009 #2
BillTodd: Thanks for your reply.
I am indeed going to use one LM317HV per phase, I should of made it more clear in my 1st post.
I am going to be using my Astrosyn MY103H702 stepper motors, thease have a max current of 1amp per phase.
I am intrested to know what caps to use to stop or limit any voltage noise.
As wile testing without any caps the stepper motor wile static will hum.
Thanks for your time.
RFQ: Simple job cutting simple shapes out of camera lens cap
By RockandGrohl in forum Projects, Jobs & RequestsReplies: 15Last Post: 20-04-2013, 01:23 AM -
TB6560 auto current reduction
By Mjolinor in forum Motor Drivers & ControllersReplies: 1Last Post: 08-12-2011, 09:53 PM -
Current Set Resistors.
By NzOldun in forum Motor Drivers & ControllersReplies: 1Last Post: 20-06-2011, 08:38 AM -
G540 Current set resistors
By blueseidboy in forum Motor Drivers & ControllersReplies: 3Last Post: 23-08-2010, 02:21 PM -
Laser Diode Constant Current Driver
By Mad Professor in forum General ElectronicsReplies: 8Last Post: 21-07-2010, 06:01 PM
