  1. Will adding reverse protection diodes across the current limiters cancel this out.
    No. When you run the motors there's a likely hood of generating large back emf from the stepper coils the diodes are to stop this damaging the LM317s.
    That looks like a normal rectified transformer output. Ripple is, what?, 3v - perhaps a bit high for a few amps of load. What size (VA) transformer and smoothing cap?
  2. The power supply I am using is out of a fruit machine, and is a Barcrest MPU-LF Transformer & Power Supply, that is as much as I know.
    This power supply has multiple outputs, I am only using one output marked at 34VDC @ 7A.
    The smoothing cap inside the power supply for the 34VDC rail is a 4700uf 80wv.
  1. RFQ: Simple job cutting simple shapes out of camera lens cap
    By RockandGrohl in forum Projects, Jobs & Requests
    Last Post: 20-04-2013, 01:23 AM
  2. TB6560 auto current reduction
    By Mjolinor in forum Motor Drivers & Controllers
    Last Post: 08-12-2011, 09:53 PM
  3. Current Set Resistors.
    By NzOldun in forum Motor Drivers & Controllers
    Last Post: 20-06-2011, 08:38 AM
  4. G540 Current set resistors
    By blueseidboy in forum Motor Drivers & Controllers
    Last Post: 23-08-2010, 02:21 PM
  5. Laser Diode Constant Current Driver
    By Mad Professor in forum General Electronics
    Last Post: 21-07-2010, 06:01 PM
