Thread: Simple Current Limiter (LM317)
If you are running these steppers unipolar why go for such a high power supply voltage? you are giving yourself so many problems by doing so.
Higher voltages only apply to designs using a chopper or PWM current limiter, not a linear design. The higher voltage can then give improved current ramping in the windings but this is not the case for a linear current limiter.
The Astrosyn steppers in unipolar configuration at 1A per phase need 6.2v. A 36v supply means the limiter will be dissipating 29W. For an LM317 design, the current set resistor will be 1.25ohm and will dissipate 1.25W, needing a 3W resistor. If you put 6 LM317 on a heatsink at 30W dissipation each (worst case) you are dissipating 180W.
For an LM317 the thermal characteristics are 4degC/W junction to case so the junction temperature will be 4 x 29 = 116degC above case, the limit being 125degC. In other words you could use an infinite heatsink and they'd still fry at room temperature!
Dropping the supply volts to 12v would run the LM317 at 4.6W, the maximum case temp could then be 106degC and the required heatsink (for 6 units at 20degC ambient) would need to be better than 3.1degC/W - say atleast 1.5degC/W for safety assuming some thermal grease between the case and the heatsink. An 80mm x 80mm CPU-style fan blown heatsink (if thats what you were proposing, typically 0.8degC/W) might just be sufficient if you can get the LM317 close enough to the centre and can get sufficient airflow. Note that a CPU-style heatsink is designed for a heat source about 20mm sq in the middle, not 6 TO220 cases bolted round the edges.
A normal extruded ally heatsink with 15 - 20mm fins will be around 3 to 5degC/W for a 100mm x 75mm piece and maybe 1 - 2degC/W if blown by a fan.
You can never have too big a heatsink with linear devices!Last edited by irving2008; 13-07-2009 at 07:38 AM. Reason: corrrected a minor maths error, aded safety margin
RFQ: Simple job cutting simple shapes out of camera lens cap
By RockandGrohl in forum Projects, Jobs & RequestsReplies: 15Last Post: 20-04-2013, 01:23 AM -
TB6560 auto current reduction
By Mjolinor in forum Motor Drivers & ControllersReplies: 1Last Post: 08-12-2011, 09:53 PM -
Current Set Resistors.
By NzOldun in forum Motor Drivers & ControllersReplies: 1Last Post: 20-06-2011, 08:38 AM -
G540 Current set resistors
By blueseidboy in forum Motor Drivers & ControllersReplies: 3Last Post: 23-08-2010, 02:21 PM -
Laser Diode Constant Current Driver
By Mad Professor in forum General ElectronicsReplies: 8Last Post: 21-07-2010, 06:01 PM
