I have two machines, one with a 10mm plunger, and a 15mm plunger. Increasing the shot size depends on the size of plunger you have. They came in three sizes, 10 (1.5cc), 12(2cc), and the largest at 15mm(2.5cc).
If you pull the barrel, the plunger slides right out. The plunger fits into a matching, removable sleeve (IIRC, roughly 75-100mm long), so they are the only two parts which require changing. You might even be able to fit in a set larger than 15mm, but your injection pressure will be reduced, and you will still have to mind the surface area so you don't blow through the parting line.
05-05-2016 #2
So, as far as you can tell the machine can't go over about 2.5 gram shot? That is unfortunate as I was really hoping to get a bigger shot out of the unit - looking for about 6 to 8 grams in fact. I have to wonder if there is any room for a redesign of the clamping or the injection pressure by either increasing the size of the air cylinder or making a latching clamp action on the mold so the injection pressure can be increased. As you say, if the injection pressure rises the liquid plastic may weep out at the mold lines otherwise.
I have a photocopy of a photocopy of the original manual for the CPU controlled version of the 2/3 (email me if you want a PDF copy - or can I put it up on this site somewhere?) and while it talks about how to remove the injection chamber I can't get the pin out from the underside of the securing part that is accessed by removing a 10mm bolt from the side of the frame just below the hopper. The instructions say to drive out the pin using a 4mm rod inserted into the hole, but I whacked that a couple of times and the pin did not move and I don't really like the idea of hitting it harder until I am sure that is the correct spot to be pounding.I will put up some photos later today of the parts I am speaking of.
05-05-2016 #3
Using standard components, yes, 2.5gm is the max. You could stretch it to 3gm, maybe more, with a custom plunger and sleeve. I think 6-8 might be expecting too much. The real limit will be the clamping pressure vs your part surface area. If you install a custom PLC (heck, a raspberry pi would do nicely), you can "double-shot" your parts to increase your volume, but again, the limit will be the surface area.
So, what is the surface area of your part? The rule of thumb is around 3 tons per square inch, depending on the resin you may require more (up to 5) or less (2-2.5 tons). Since a new machine is limited to 5 tons, you can't really make a part much larger than around 1sq". I have made a 1" square with 1/8" radii in the corners successfully, and I have also managed to get it to blow the mold apart slightly. Maybe I did not have enough preload on my mold (see below), but that gives you an idea of max size.
The clamp already has a toggle action, with leverage, etc. It's a pretty complicated system, with quite a few parts considering the size of the machine. It's because the one air cylinder both closes the mold and also injects the plastic, and it does it in a mechanical sequence. There is no physical way to push material without closing the mold. As far as increasing the clamping tonnage, the levers in the linkage will be one limiting factor (like a fuse), and the tie rods will be another limit. The way it's designed, with full clamp force, the tie rods already stretch .018". If you want to double that, you'd be stretching almost a full millimeter, and I doubt it will last long like that.
Moving on, the rod holding in the barrel has a screw in one side; you have to loosen and remove the screw. It's like a pinch bolt, IIRC, so the screw pulls the rod (which has a flat taper on one side of it) into the bottom of the barrel, thereby pushing the barrel up. Once you loosen the screw, you can push on it on the screw side (maybe tap the screw after one turn loose), and the tapered rod will pop out the other side.
I already have a manual, and I also downloaded a PDF from this forum; it had a few bits of information that mine did not. If your version has more information, then I'd appreciate it, otherwise I'm set.
I have a sales brochure, and that lists the specs of the plungers.
06-05-2016 #4
Thanks for the detailed help. I believe you are suggesting that it would be more effective to find a machine with a larger capacity than my little 2/3, keeping it for the smaller jobs. I do love tinkering though and 'fixing' the machine so it does a bit more could be a fun activity.
Is the maximum surface area one square inch or one cubic inch? Slight difference...
As an example, one part I am looking at making is roughly 2" X 3/8" and is hollowed out, and has a small post. Weight is around 4gm (my postage meter doesn't handle small weights well). Made of Nylon. Are you suggesting that this can be done using two shots? How would one do that?
I did try tapping the 10mm bolt once loosened but no joy. Perhaps it needs to be heated up to 200C first - that suggestion was in the manual too.
Where is the FTP archive here? I'd be interested in seeing what I may have that may be missing.
Thanks again for your advice!
06-05-2016 #5
Trying to squeeze two dozen clowns into a Smart ForTwo might be fun, and it might be possible, but the car will not get far. Even if you can get it to drive, the first bump you hit will collapse the suspension. Similarly, you might be able to increase the capacity of your Rabit to 4x its design rating, but it was not designed for greater forces, so it won't last long.
Think about the "units" of pressure the machine is rated for... pounds per square inch. The injection pressure with a 10mm plunger is roughly 20,000 psi. On a part that has one square inch, that is 10 tons. The force keeping the mold closed is 5 tons. Not going to happen. A larger plunger has less force, so the 15mm plunger only puts out 8520 psi, which is about 4.3 tons... enough for 1 square inch, if everything is absolutely perfect. A larger plunger will have even less force.Is the maximum surface area one square inch or one cubic inch? Slight difference...
And when I say 1 square inch, that is "projected area," or the area at your parting line. That is the amount of area where the plastic tries to press your mold halves apart. Holes in the part are subtracted from the total area, since there are no forces pushing the mold apart where there is no plastic. On the part, walls that are perpendicular to the parting line do not try to push the mold open, they try to push the side of the mold out, so they don't really count when sizing the clamping force.
If you replace the controller, you can set it up so the plunger goes in to its max and immediately withdraws and plunges again. It must be fast, or the first shot will freeze off before the second gets there. It will not be an easy setup. You will need to use the Mold Closed sensor to detect when the plunger is withdrawn, and immediately turn around. It won't work with materials that freeze quickly. With soft sticky rubber pellets I had to use an air cylinder to pack the barrel (they were making a bridge, and would not fall)...you might have to do this so you are not waiting on gravity to fill it between shots.As an example, one part I am looking at making is roughly 2" X 3/8" and is hollowed out, and has a small post. Weight is around 4gm (my postage meter doesn't handle small weights well). Made of Nylon. Are you suggesting that this can be done using two shots? How would one do that?
Just remember, this trick will not increase your clamping force. It will only fill up a deep cavity that has an acceptably sized area at the parting line.
After much googling to find the pesky link, I realized I downloaded it from your link!I did try tapping the 10mm bolt once loosened but no joy. Perhaps it needs to be heated up to 200C first - that suggestion was in the manual too.
06-05-2016 #6
Thanks for sending me your file, I have now edited my copy incorporating your additional pages and some duplicate pages that have some good handwritten notes. If anyone wants a copy please feel free to download it from here.
06-05-2016 #7
Considering the higher quality of the scans of my manual, you might consider migrating your extra pages into my file, instead...
The schematic on pg 47 with the timing diagram on pg 48 is something I added. When I got my machine, it had two timers on it that were supposed to cycle the ejector pin, but they did not work. I replaced them, and also added that circuit so the ejector pin would not run continuously when the machine stopped.
My first injection mold and the Rabit HY-4 injection molder
By gavztheouch in forum Moulding MachinesReplies: 46Last Post: 13-11-2017, 03:22 AM -
eBay: Another Austin Allen GNAT injection moulding machine
By steve400 in forum Items On eBay UKReplies: 1Last Post: 24-06-2015, 11:36 AM -
eBay: Austin Allen GNAT Injection Moulding Machine - runs on 240V
By steve400 in forum Items On eBay UKReplies: 2Last Post: 19-04-2015, 05:36 PM -
Spare Capacity?
By Lance in forum General ElectronicsReplies: 0Last Post: 25-05-2011, 10:49 AM -
Increasing timing pulley bore size from 3mm t0 3.175mm
By divdav in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 14-05-2011, 09:45 AM
