Thread: Z drive not working
14-04-2016 #1
My z drive will work when connected will x axis cable but won't work using its output.the Sri will move on screen the motor is making noise.below is a picture on the diagnostic screen there is a fault but I don't know how to repair it.
Sent from my SM-G361F using Tapatalk
14-04-2016 #2
When did it last work properly?
What has changed since then?
You've done half the diagnosis work, proving that tour Z motor works on an alternate driver, now you need to try your Z driver on another motor to definitively isolate the problem to just your Z driver.
You don't give any details of your hardware, if I had this fault on my system I would swap out a driver but this is not an option on "All in One" Break Out Board and driver units where one failed driver renders the whole board scrap.
14-04-2016 #3
I Changed the leads from the z to x then the x worked the z fine but the z driver would not work the x .I got the machine with this problem
14-04-2016 #4
Examine all the components and tracks on the faulty driver section of the board (both sides) and compare to the good ones, I'm betting there's a toasted component or track somewhere on there.
Z drive not working on cnc plasma
By whensparksfly in forum Machine DiscussionReplies: 15Last Post: 10-05-2016, 02:16 PM -
FOR SALE: Assembled Working Portabee
By calida in forum Items For SaleReplies: 0Last Post: 19-09-2015, 11:17 AM -
x&z not working
By cncjohn in forum Linear & Rotary MotionReplies: 5Last Post: 18-08-2013, 12:58 PM -
EXPERIENCE: Working with JAZZCNC
By m.marino in forum Trading Experience & FeedbackReplies: 0Last Post: 02-10-2012, 11:47 AM -
BobCAD CAM V24 Working with DXF files
By aldepoalo in forum BobCAD-CAMReplies: 3Last Post: 19-03-2012, 08:17 PM
