ok thank you very much to everyone anyway
29-08-2016 #2
Why not wire the full part profile then slice?
Hold slices in softjaws in zero point system to perform any cnc operations.
Finished.....
30-08-2016 #3
The description is unclear but it sounds like some of the jobs are forgings being machined to finished size?
30-08-2016 #4
Its not very clear what you are doing exactly, obviously is one thing machining 200mm thick part or 10mm thick part. But from what i have seen and know- what you are doing is done usually either using a vice and parallel plates below part, either 2 piece vice for long parts, parallels if needed and a combination of screws and clamps.
Skimming flat on mill is achieved by fly cutter, for your case best would be custom heavy duty fly cutter so you cut at once as much wide as possible. meaning made so that is reinforced with disc.
30-08-2016 #5
It is clear what hoezap is doing. The only way to really speed it up is change the process. He is already wiring. Wire the whole job. The speed increase is seen when the part is sliced...
31-08-2016 #6
01-09-2016 #7
Delcam 2016 demo version or price... pleeeease heeelp!
By hoezap in forum CAD & CAM SoftwareReplies: 2Last Post: 01-05-2016, 05:27 PM -
RFQ: RFQ: Very Simple Machining of Two Aluminium Parts Required
By biketrialsdave in forum Projects, Jobs & RequestsReplies: 0Last Post: 15-12-2015, 12:01 AM -
scm tech 95l cnc machining centre User manual or parts lists
By george uk in forum SCM Group RoutersReplies: 13Last Post: 28-04-2015, 08:18 AM -
RFQ: small machining job??
By Wobblybootie in forum Projects, Jobs & RequestsReplies: 8Last Post: 25-02-2011, 01:04 PM
