Thread: Noobs' Feeds & Speeds
Gary,
I'd try a ramped profile cut, experiment with shallower DOC to see what the calculator says.
Any calculator will assume a rigid milling machine though, which few of us have.
See what the calculator says about a single flute cutter, they're great for chip clearance,
- Nick
19-04-2016 #2
Hi Gary,
I take it you have filled in the setup page for your machine i.e. use generic gantry router and specify the weight of the gantry etc?
The two settings you don't understand are:
Cutting Width = Step over - what CAM strategy are you using to mill the cylinder? (I assume from a square block) If you are going for a slot cut then you should use 6mm and if using side milling of some sort then use 2.4mm on a 6mm cutter (although a 6040 machine may struggle with this much depending on depth of cut).
Feed Limit = the feed rate of your machine before stalling occurs or the feed rate limit you have setup in the machine control software (MACH3?) (The 2% is the % of the limit the suggested feed rate is running at e.g. GWizard may suggest 1000mm/min for a machine with a limit of 10,000mm/min, which would be 10%).
As Nick suggests I would try a single flute cutter for aluminium, unless you are going to side mill the block inwards to the cylinder using something like adaptive clearing or a similar strategy and then I would say your feeds for a 3 flute cutter are too low.My CNC Projects: https://www.youtube.com/imadethisoncnc
19-04-2016 #3
Hi Nick and Washout,
Thanks for the explanations and ideas. I entered various values into GWizard and selected 'Fine Finish'. Here are the final figures calculated:
1 flute 6mm carbide endmill
50mm stickout (Bottom of collet to tip of endmill). The block of Aluminium is 40mm thick.
1mm depth of cut
15671 rpms
2.76 mm/sec (165.5 mm/min)
Fine Finish
Any higher and the deflection is too much, so now to buy a good endmill :)
To use a 3 flute, I would need a spindle speed of 36,000rpm. My 6040's max is 24000rpm. I don't know the weight of my gantry. I didn't think to check that before assembly. I have purchased a 'clock micrometer' to check the alignment of the gantry to the bed.
"using something like adaptive clearing". OK, I need to read some tutorials.
Gary
19-04-2016 #4
Gary,
Have you tried a shallower cut with faster feed with the 3 flute? You ought to be able to get enough advance per flute that way, you'll need air to clear chips and cutting lubricant (WD-40 or a 30/70-20/80 engine oil/paraffin mix) to reduce chip adhesion to the cutter, a quick squirt into the cut once every pass or two is usually adequate,
- Nick
19-04-2016 #5
Hi Nick,
OK, back to GWizard to try new numbers. I have an aerosol of cutting oil and a small air compressor and gun. As this will get messy (I was hoping to make dry cuts) I need to find/make a large perspex cabinet/cover. Yet another project, O Joy!
Gary
19-04-2016 #6
Hi Gary, my 6040 are not too fond of deep (long stickout) cuts with any 2 flute cutters. 1 flute seem to be much more in harmony with the rigidity, on my machine at least. The cutters I prefer, are from sorotec.de, 1 flute alu end mills. They stay sharp forever, and dont break easy.
Just my thought on what have worked best for me.
19-04-2016 #7
Speeds and feeds
By eurikain in forum Workshop & EquipmentReplies: 3Last Post: 26-03-2016, 06:00 PM -
Feeds and speeds software
By suesi34e in forum Swarf & Chip ManagementReplies: 4Last Post: 22-03-2016, 10:30 PM -
Feeds and speeds software?
By Leadhead in forum Computer SoftwareReplies: 9Last Post: 31-10-2015, 09:34 PM -
Feeds and speeds
By dudz in forum Tool & Tooling TechnologyReplies: 0Last Post: 26-08-2013, 11:42 AM -
Speeds and Feeds
By Web Goblin in forum Tool & Tooling TechnologyReplies: 0Last Post: 20-09-2012, 01:38 PM
