    In the photo in post #4 there's a gap between the red buffer and the driven section of the coupling, either the ballscrew moved down or the driven section of the coupling moved down.
    If the driven section of the coupling can move down then it's not tight enough and would also slip in rotation, and because more torque is required to lift Z than lower it the axis would slowly slip down.
    If the coupling driven plate is slipping then stripping, cleaning, then reassembling with a stud & bearing fit compound may provide a temporary fix,
    - Nick
    I cannot see this being the problem more likely the simple options, ER11 thread damaged and not locking collet properly, material insufficiently secured if clamped at edges acrylic will lift in centre with any sort of up cut helix, wrong collett size used, whatever is causing a 3.75mm shift is gong to be measurable so measure collet protrution, relative position of ballscrew, deflection in frame or material plane with dial indicator etc and identify movement.
    Before trying to remedy a problem identify it and save a lot of unecessary speculation.
  3. The Following User Says Thank You to lucan07 For This Useful Post:
    Quote Originally Posted by lucan07 View Post
    I cannot see this being the problem more likely the simple options, ER11 thread damaged and not locking collet properly, .
    Could you speculate on how this would cause the bottom section of the Z axis motor coupling to move into contact with the screw underneath, leaving a gap in the coupling assembly which should not be there it as can be seen in the video?
    :D
  5. #4
    :D
    The coupling can slip down onto the ballscrew and off of the motor shaft without the screw or the axis actually moving poor grip and gravity with a little help from vibration, also the video of the screw is someone elses problem not stated by this poster as far as I can tell.
    If a betting man I would look at first item discounted as the problem, thin double sided pads probably applied towards edges with a little give amplified at centre as a helix screw into piece pulling it up or pulling the bit down with forces generated to clear the chips, the solutions are being given without identifying the problems which is illogical.
  6. The Following User Says Thank You to lucan07 For This Useful Post:
  1. Cutting deeper in areas???
    By alboy in forum Gantry/Router Machines & Building
    Last Post: 29-01-2015, 05:54 PM
  2. Small 3D Engraving
    Last Post: 01-01-2015, 10:46 AM
  3. Font cutting
    By petesos in forum Machine Discussion
    Last Post: 17-05-2014, 08:14 PM
  4. RFQ: Wood Sign/engraving required, small job one off money waiting...
    By njhussey in forum Projects, Jobs & Requests
    Last Post: 21-09-2013, 07:12 PM
  5. Hi font help please
    By cockneyrebel in forum Computer Software
    Last Post: 12-04-2013, 06:39 PM
