20-04-2016 #11
OK so I mixed up the poster of one part of thread it does not change the point that whatever is moving 3.75mm should be easily identifiable, if the ball screw is dropping the retaining nut on base would be 3.75mm below expected position and obvious. this is obviously a poor design the retaining of ballscrew appears to be on wrong end but unless ballscrew dropping 3.75mm an easily visible amount another fault is likely to be the problem.
The Following User Says Thank You to lucan07 For This Useful Post:
Cutting deeper in areas???
By alboy in forum Gantry/Router Machines & BuildingReplies: 20Last Post: 29-01-2015, 05:54 PM -
Small 3D Engraving
By magicniner in forum General DiscussionReplies: 2Last Post: 01-01-2015, 10:46 AM -
Font cutting
By petesos in forum Machine DiscussionReplies: 9Last Post: 17-05-2014, 08:14 PM -
RFQ: Wood Sign/engraving required, small job one off money waiting...
By njhussey in forum Projects, Jobs & RequestsReplies: 8Last Post: 21-09-2013, 07:12 PM -
Hi font help please
By cockneyrebel in forum Computer SoftwareReplies: 3Last Post: 12-04-2013, 06:39 PM
