Just found these on eBay, £10 inc P&P !
Link: http://m.ebay.co.uk/itm/162036991360Description
Switching power supply, closed, 24V / 8,3 A / 200 W
Switching Power Supplies with built-in RFI filters. Low ripple, closed design with screw terminals. Overload protection by switching off, auto recovery. Short-circuit proof. 100 % burn-in test under full load.
Power: 200 W
Input: 85 - 264 VAC, 120 - 370 VDC
Output: 24V / 8,3 A
Manufacturer: MEAN WELL
Article number of the manufacturer: SP - 200 -12
Packaging weight: 0.849 kg
RoHS compliant
General type switching power supply
Execution closed
Electrical values
Voltage 24 V DC
Current 0 - 8,3 A
Input Voltage 85 - 264 VAC
Input voltage 120 - 370 VDC
Inrush 60A
Ripple 100 mV
Features
Short circuit protection yes
Overload protection yes
Connections / Interfaces
Connection Screw
Bargain no?
.MeLee
20-04-2016 #2
Oh bu**er. I just went and bought one for a higher price from aliexpress a few days back and I now have to wait a month for it to arrive.
20-04-2016 #4
I've ordered a 60V 10A Mean Well for powering the motors. I also bought a separate 24V 3.2A power supply for powering the motion control unit (DDCSV1.1). It requires 18-32V >0.5A. I am thinking of using it to power a little 24V brush-less dc submersible pump for spindle cooling also.
21-04-2016 #5
Damn it sorry about that!
This 24v one is the best price I could find vs form factor, it's only a 2amp rating power supply so it depends if you want to run other stuff from it, the problem/issue (for me at least) was that as you start going up in amps, the size of the unit gets bigger.
DC 12V/24V/5V Universal Regulated Switching Power Supply for LED Strip CCTV Hot
Link: http://m.ebay.co.uk/itm/222029680440
There is plenty of other sellers on there, the best prices seem to be coming from the sellers advertising these switch mode psu's as l.e.d driver units, there's quite a range to choose from once you start looking.
Just a note to anyone reading: Ideally you want a linear power supply to power your motors/drivers really, switch mode units do work though.
.MeLast edited by Lee Roberts; 22-04-2016 at 12:49 AM.
This one is the best 5v one I could find, again unit size being the factor:
AC to DC 5V 5A 25W Volt Transformer Switch Power Supply for Led Strip Light PO6Z
http://m.ebay.co.uk/itm/172053699383
.MeLee
26-11-2016 #7
Little update, I needed a couple of 12's recently for a project and found the listing below has a pretty good selection for 12v and 24v switching power supplies: 25W/30W/50W/60W/100W/120W/150W/180W/250W/300W/360W/400W
12v 80w 6a £10
http://www.ebay.co.uk/itm/282219610030
12v 25w 2a £6.50
http://www.ebay.co.uk/itm/282219610030Lee
26-11-2016 #8
Did you get them OK? this eBaytrader has some shitty feedback in the last month. Still a Meanwell PSU is a fairly good one !
R
02-12-2016 #9
Power Supplies
By dcrowder in forum Machine DiscussionReplies: 10Last Post: 27-01-2016, 08:32 PM -
Power Supplies
By GTJim in forum General ElectronicsReplies: 5Last Post: 26-04-2013, 04:06 PM -
Minimal-cost Power Supply Strategy - Repurpose Laptop Power Supplies
By LoveLearn in forum General ElectronicsReplies: 0Last Post: 25-01-2012, 09:29 PM -
FOR SALE: Power supplies
By Jimmybristol in forum Items For SaleReplies: 2Last Post: 21-05-2011, 07:37 PM -
FOR SALE: 3 x 48V 12.5A Power supplies for sale
By Jimmybristol in forum Items For SaleReplies: 7Last Post: 25-03-2011, 07:18 PM
