Near the desert in Almeria
20-04-2016 #2
Ah shame I am over at the other end next week about 50K from Malaga.
Do you know the inductance of the motors? You might run into problems with the ball screws that long without rotating ball nuts.
For Plasma you WILL need some good electronics and they will have to be able to slave the second screw with homing switches. cslabs make some good controllers. Dean (Jazzcnc) is the go to person for advise on them here as he has fitted lots of them...Clive
08-12-2016 #3
After a ridiculously busy summer I'm finally finding a bit of time to try and progress my machine. I decided - after a couple of false starts - that I would be much better off if I at least learnt the basics of what was involved with the electronics so I've had a go myself.
I've gone with an ESS as this seems to have the ability to do what I need including slaving an axis when I get round to fitting it. Wired it off the table and it did at least turn the motors!!!!! Can't tell you how suprised I was.
Will post a couple of pics of progress tomorrow.
Definately some issies ahead - not least of which is initial height detection so if anyone can point me to anything of interest it would be much appreciated. I have had a search but have struggled to find much.
08-12-2016 #4
09-12-2016 #5
Oh dear should have took Clives advise and asked about Cslabs. This comes with built in HTC and it will slave axis. (It won't home to indvidual SW thou).
Also 24V I/O is much better for plasma than 5v which ESS uses. I can tell you for sure because tested one that my TIG welder will Stop ESS in it's track when torch fires up (This is one my tests for controllers) but Cslabs units don't even flinch.
Not saying it will do this for you because the test is little extreme as I fire torch right next to Controller and don't exactly take lot of care on the grounding etc but I do the same for Cslabs which handles it ok.
10-12-2016 #6
You may well be right Dean. Will have to suck it and see. I do have a good distance between my table and where TIG is.
Have a question on Hypertherm interface cable wiring if anyone can help?
10-12-2016 #7
Just so I know - which CSlabs would you have used?
13-12-2016 #8
Right - before I blow something.
I need to connect the hypertherm interface cable to my BOB (one of the ones with the blue relay) and my Proma 150THC. Interface cable has 3 pairs of wires black/white (which according to proma manual are spoken for) Green/Black which are Start. Am I right in thinking these are to be connected to the relay output (spindle on/off)? And lastly red/black which are the Transfer wires - not sure if I need these with using this THC or what to do with them otherwise?
There is mention of Pin 17 for relay but not sure if relevant.
Proma has been wired in according to supplied instructions and will be tested tomorrow.
So far everything appears to be working - control cabinet looks a little messy but a work in progress I feel.
Any help greatly appreciated.
Help With a number of build issues & uncertaintities
By bigstu67 in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 24-09-2014, 03:54 PM -
Build Log: Robotising a RC tank (first attempt)
By Fivetide in forum General ElectronicsReplies: 15Last Post: 01-10-2012, 10:06 PM -
Plasma Attempt #2
By Robin Hewitt in forum DIY Plasma Build LogsReplies: 21Last Post: 02-09-2012, 08:05 PM -
my plasma build mk2
By oadamo in forum DIY Plasma Build LogsReplies: 8Last Post: 08-06-2011, 10:25 PM -
My first Plasma build
By D-man in forum Plasma Table MachinesReplies: 4Last Post: 10-07-2010, 02:27 AM
