    Andrew it will be fine on standard plug. This is done all the time without problems.
    Clive is also correct that 1.5mm2 is fine for the connection between VFD and Spindle. 2.5mm2 should be used from mains to VFD but to the spindle you are better with 1.5mm2 because it's easier to fit into the spindle connection socket and because the spindle is only rated 8A then 1.5mm2 is more than enough.
    In use while cutting you'll rarely if ever pull the full 8A.
    I don't set my VFD to Display RPM just Amps so I can monitor for cutter wear so I'm very aware of the current they pull. For instance milling aluminium 4mm DOC full slot engagement with 8mm 3 flute cutter running 1000mm/min I only pull around 3A when cutter is new. Max is 5A when cutter is so worn it's crying stop.!!
    Only when you jam up or Bog down will you get close or exceed 8A in which case the VFD should be set to Fault if above set amount for any period of time.
    Hi Jazz
    Thanks for the reassurance. I'll give it a crack with a normal plug and some heavy wire. I'm a bit nervous about the 22 amp rating on the inverter case. I'd be grateful if any forumites that have used this vfd Hitachi wj200-022sf with a normal plug on it can chirp in with their opinions. I'm going to be using the spindle for wood routing and I know from experience that sharp cutters and and a powerful motor and not to deep cuts leads to a good finish and less stress on the machine and my nerves. I'd like to thank everyone here for their help as this is my first interaction with this forum, and look forward to further posts and replies.
    Thank you all.
    Andrew
    Thats interesting. Thanks for sharing. Great info. Does it work with 6mm 2 flute cutter also? Or its to small to see well difference?
    Yes works just same with 6mm.
    Edit: The Chinese VFD's can be a little slow to re-act but do show difference. Better drives like my ABB monitor it so precise I can tell when it hits hard or soft spots pretty much instantly. It's saved my skin a few times being able to compensate for any changes.
    Andrew I haven't personally used the Hitachi but I built a machine for some one who uses the same VFD with same spindle and it's perfectly fine. Infact the whole machine including VFD runs from 13A socket run down to shed via electrical extension cord. This was 5yrs ago and still hasn't burnt the shed down so can safely say it's ok.!!
    Also My ABB 2.2Kw VFD is rated 25A and still it's fine run from 13A. I fit lots of these 2.2Kw Spindle VFD setups and I haven't had one that taxs 13A so sleep safe.!
    Hi Jazzcnc
    Thanks very much for the heads up. I've got some O'Reillymen in at the the moment doing some work and they said they could wire in a stronger breaker if need be. The mounting point would be right next to the distribution board so the cable would'nt be more than half a metre. I was just surprised that in the mounting instructions Hitachi recommend 5.3mm² which seems mega thick even for 20 amps here's a link to the manual. http://www.hitachiacdrive.com/wp-con...05/NT3251X.pdf
    (my one is the wj200-022sf) thanks for your help again.
    Andrew
    Hi
    Me again, I hope this isn't a stupid question. Is it necessary to have the input phase correct on the ac mains side of a vfd. The reason I asked is the mains plugs over here in Austria are not orientated, unlike the British mains plugs. Using the European plug if correct orientation is required i'm going to have to use some kind of marking. I don't want to blow up the hitachi vfd as it wasn't cheap.
    Andrew
    My view, and nothing that I've seen in the Hitachi manual tells me otherwise, is that the VFD would work with the phases reversed.
    Clearly, the recommendation must be to wire the phases correctly to avoid confusion and hazards later on. But, it'd work regardless.
    Quote Originally Posted by the great waldo View Post
    Hi
    Andrew
    In the UK the neutral is bonding to the Earth at the consumer unit generally with the phase being fused.
    But in some countries the mains is supplied by a split system ie 220V would be 110 - 0 - 110 with the earth being the 0 that is why the plugs are not polarised they also use two pole mcb's one in each leg.
    I think you will be fine which ever way round you connect it. Do you know what system you have re earthing and breakers ie two pole or singe?
    Hi Clive
    The breakers are 2 pole according to the switch diagram on the breakers. I don't think the mains here is a split system. 3phase here is at 380v: all my larger tools that I dragged over from England years ago work fine here. From what i've seen on the internet vfd's have basic rectification at the front end so i'd imagine it should work ok. I just wasn't sure if hitachi put some kind of fancy electronics in the vfd that is polarity sensitive. I just had a look in the distribution box without the cover and the breakers are double pole but phase and neutral each use one side of the breaker.
    Andrew
    Hi
    Andrew
    I guess you have already connected the VFD and found out that it does not matter which way you plug it in, but just to make it clear for everyone else as well...
    If you use a one phase VFD it does not matter which way you connect it, as long as you connect one wire to phase and the other to neutral and the third (yellow/green) to PE (protective earth). The main thing is not to confuse earth and neutral, those two are TOTALLY different in the European net. Inside the VFD it makes no difference if neutral and phase connections are switched, so you can safely plug in the VFD in any plug orientation, it really doesn't matter, just like the vacuum cleaner you use, you never know which is phase and which is neutral, it still spins the same way and works just as well.
  1. help connecting a pot to huanyang vfd 2.2
    By edgas10 in forum General Electronics
    Last Post: 14-08-2016, 06:45 PM
  2. Connecting power supply for 220v
    By Noplace in forum General Electronics
    Last Post: 10-02-2015, 08:34 PM
  3. Mains power supply? How have you done it?
    By gary_808 in forum Gantry/Router Machines & Building
    Last Post: 01-02-2015, 04:45 PM
  4. Connecting VFD
    By andrew583 in forum Spindles & Drive Motors
    Last Post: 19-08-2014, 01:01 AM
  5. Mains, PSUs and other goodies.
    By Rogue in forum General Electronics
    Last Post: 28-08-2012, 12:37 PM
