Thread: Greetings from Nottinghamshire
13-06-2016 #21
Here is the link
http://www.aliexpress.com/item/HIWIN...999.263.UMYDXN
The Following User Says Thank You to Stressedwoodman For This Useful Post:
15-06-2016 #22
No one got an opinion whether medium preload is too much or not for a medium sized CNC router.? I am finding difficult to predict what sort or resistance this would be from the data sheets. I don't want to end up needing bigger motors just to move things.
16-06-2016 #23
Medium preload should be fine...
Higher stiffness at the expense of life span and force required...negligible for home build :).
Stiffness values http://www.automation4less.com/pdfs/hiwinaglg.pdf
.MeLast edited by Lee Roberts; 16-06-2016 at 07:33 AM.
I saw BST mentioned somewhere in a post earlier too, while browsing for Bellows and Wipers (neither of which I installed when I finished the machine!) - is it BST Automation on Aliexpress you refer to? I think a couple of years ago I read Chai from Linear Motion Bearings was good so I sourced from him. Where do people tend to source these days (I might need another ballscrew if I can't get the wooddust out of this one!) and what's the quality like?
EDIT: Oh or these? BST LinearLast edited by mattnedgus; 29-06-2016 at 08:56 PM. Reason: added other possible supplier!
30-06-2016 #26
Yes the link is http://www.aliexpress.com/store/314742 he has a gmail account on there and Fred always answer his emails I would contact him via email for a quote.
I believe Chai is still in business...Clive
01-07-2016 #28
NEW MEMBER: Hi from Worksop in Nottinghamshire
By Waylander2 in forum New Member IntroductionsReplies: 3Last Post: 01-11-2010, 11:11 PM -
NEW MEMBER: from a shed in Nottinghamshire
By Andrew Wilding in forum New Member IntroductionsReplies: 3Last Post: 17-09-2010, 12:34 AM -
Nottinghamshire Machining services for one-offs and prototype work
By jpcnc in forum Opportunities Available & SoughtReplies: 2Last Post: 25-07-2010, 09:57 PM -
NEW MEMBER: Hiya from Nottinghamshire
By jpcnc in forum New Member IntroductionsReplies: 8Last Post: 22-07-2010, 09:39 PM
