    Yes, i always probe with the actual tool.
    I tried cutting the Illustrator file tonight, yes it cut far smoother but it was generated as two paths which gave me a letter with an inverted V in the middle ;)
    A settings issue, wrong font, wrong code generator, other problem?
    Lots to learn here...
    I think Vectric Aspire / V carve/ beats all when we are speaking about signs and engraving
    Blooming expensive though :(
    what are you using now?
    My CNC world consists of CAD - either Deltacad or Illustrator, CAM - SheetCam, CNC - Mach3
    Apart from some free programs that i downloaded for messing about with that's about it.
    Vectric V-Carve was about £400 I think - a lot of cash for something that is unlikely to bring cash in via sales I think.
    Lives in Marple Stockport, United Kingdom. Last Activity: 21 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Yes but you can use it to import dxf files and cam them with it.
    Following assistance from John S (thanks John) I have done some more engraving, this time using code generated in V-Carve and using my 3mm 30deg 0.2mm carbide cutters, the results were mind-blowing - razor sharp lettering, no burrs on the edges, could not be better and proves the machine is totally capable of detail work...
    It was not without issue though as I am 99% certain that the first plunge took the ridiculously fine tip off the tool as the first pass at Z-0.25 was air-cutting, pretty certain i could see the tip come off as i was watching pretty closely. The cuts above were done after this though so the results didn't suffer, maybe too fast a plunge rate?
    So, in the last few days I now have a working setup of Vectric, nice software it seems, still reading the manual ;) It is intuitive though and have got a test text file I was messing with, setup some tools, hopefully using the same settings extracted from Johns' file but this time using a 3mm 60deg carbide bit as this angle seems the most common?
    The results were nowhere near as good and I was bit disappointed with them - there are burrs on the edges and the cuts are generally crap under a magnifying glass looking like they were hacked out with a machete ;)
    So, obviously lots to learn here, any pointers???
  1. Well it passed the full Test cut.
    By m.marino in forum General Discussion
    Last Post: 15-09-2012, 09:20 PM
  2. Test of new vinyl cutter
    By evildrome in forum Tool & Tooling Technology
    Last Post: 17-01-2011, 12:25 AM
  3. Test cutting materials
    Last Post: 05-12-2010, 10:27 AM
  4. Mach3 - Test Cutting
    By sfallan in forum Artsoft Mach (3 & 4)
    Last Post: 14-09-2010, 10:10 PM
