    Yes, Mach3 and 2010 screen-set.
    A file would be good, thanks
    OK, I'll sort you something out tonight unless you want something specific like text and size.
    Screen set will not have anything to do with it, we use a custom one anyway with everything we need on one screen.
    Email me details of the cutters, included angle and tip flat as it alters the appearance on V carve files if not matching. When they match you get a sharp corner to the text, if incorrect you get an indented radii in each corner.
    john [at] stevenson-engineers.co.uk
    John S -
    Just had a look at the code and it is indeed made up of thousands of lines of straight cuts.
    I did a quick file in Illustrator then imported that into sheet-cam and with the same tool it now creates I/J arcs so in theory at least that file should cut a whole lot smoother I think.
    Yes, many times this is the reason, the line thing instead of curves. I always magnify before generating path, to make sure all is smooth .
    I would say also for fine engraving to have the Z0 using probing with the V bit itself is the best method. That, and knowing the exact tip size.
    Yes, i always probe with the actual tool.
    I tried cutting the Illustrator file tonight, yes it cut far smoother but it was generated as two paths which gave me a letter with an inverted V in the middle ;)
    A settings issue, wrong font, wrong code generator, other problem?
    Lots to learn here...
  6. #16
    I think Vectric Aspire / V carve/ beats all when we are speaking about signs and engraving
    Blooming expensive though :(
  8. #18
    what are you using now?
    My CNC world consists of CAD - either Deltacad or Illustrator, CAM - SheetCam, CNC - Mach3
    Apart from some free programs that i downloaded for messing about with that's about it.
    Vectric V-Carve was about £400 I think - a lot of cash for something that is unlikely to bring cash in via sales I think.
  10. #20
    Clive S's Avatar
    Lives in Marple Stockport, United Kingdom. Last Activity: 19 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Yes but you can use it to import dxf files and cam them with it.
  1. Well it passed the full Test cut.
    By m.marino in forum General Discussion
    Last Post: 15-09-2012, 09:20 PM
  2. Test of new vinyl cutter
    By evildrome in forum Tool & Tooling Technology
    Last Post: 17-01-2011, 12:25 AM
  3. Test cutting materials
    Last Post: 05-12-2010, 10:27 AM
  4. Mach3 - Test Cutting
    By sfallan in forum Artsoft Mach (3 & 4)
    Last Post: 14-09-2010, 10:10 PM
