Thread: Interesting Kickstarter project.
Disclaimer: I have no connection with this project whatsoever apart from being a backer.
I came across this kickstarter project which seems to promise to take most of the pain of setting up Linuxcnc for someone unfamiliar with linux. I thought folks here might be interested.
https://www.kickstarter.com/projects...ed-cnc-control
If you are interested, you might as well make use of the early bird offer and help them get up and running.
PS: I wasn't sure which area of the forum would be most appropriate for this so I've put it here in the general discussion section. Could a moderator please move it if it belongs elsewhere.
The Following User Says Thank You to nirmal For This Useful Post:
21-04-2016 #2
Be a good kickstarter project if they did it with a decent screen set instead of the AXIS one which is little more than etch-a-sketch on acid.
John S -
21-04-2016 #3
I emailed the designer of the board to enquire about support for spindle encoder input for thread cutting on a cnc lathe. Unfortunately this board does not support encoder input.
Despite this, it is probably still an excellent deal for a milling machine or a router if it does what it says on the tin. €150 or even less (after adding in the price of a beagle bone black) for a complete plug and play motion controller including software seems pretty good to me.
21-04-2016 #4
Still needs things like monitor etc.
Get one of these for £119 complete stand alone
http://www.aliexpress.com/item/50KHZ...001500686.htmlJohn S -
22-04-2016 #5
I think the price they're offering it at is pretty terrible - he should be able to get that board made and populated in China for £5-£10. That plus copying a bit of software on to an SD card ... doesn't seem right to profit so much from open source software.
Also, the board doesn't need the opto-couplers for the stepper drivers almost everyone uses, as they're already isolated. Remove those and the cost is now well below a fiver.
22-04-2016 #6
John - Your Aliexpress "box" looks very neat. Could you elaborate on it a little please. i.e. some pics of your setup and a word or two about setting it up for my non electronic brain would be well recieved if you have a moment.
22-04-2016 #7Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
23-04-2016 #8
I agree with you that it probably could be better specified, but I think his USP is that it comes with his custom made user interface which promises to make set up a breeze and is essentially ready to plug and play right out of the box. While this is no big deal for people with cnc experience or a technical background, it is quite attractive for non technical newbies like me as it makes linuxcnc a realistic option to try out for a relatively low cost which wouldn't be the case otherwise.
I think it is priced to recover development costs upfront, as there will be cheap clones appearing on all the popular far eastern auction sites within a few months if it is released commercially. I can't really fault him for that if it is his business plan.
I have one of the better specified aliexpress motion control boxes on order. It cost £114. If I get hit for taxes and duty, it will cost about the same as this so apart from needing a keyboard, monitor and mouse (which I already have lying spare) the costs are roughly in the same ballpark. It may or maynot perform better than this or the traditional parallel port PC/ Mach 3 solution but it is nice to have a choice that is usable for someone with rudimentary knowledge.
24-04-2016 #9
I agree with magicniner. A cheap PC is much better. I tend to go for a Dell as even the newer ones can still come with a parallel port.
If you don't want a PC then something like a Smoothieboard gives you a lot more (like stepper drivers).
24-04-2016 #10
Had an old Dell P4 and 512Mb Ram. Windows Xp. Bought from boot sale for 20E. It was ancient when i bought it. Used it everyday on my CNc for a couple of years, no filter, no cover, no aspiration on machine. Once per year blow away the 20mm at least dust accumulated inside. Workshop inside 50 degrees C in summer, inside the Dell, who knows how much. Gave it to a friend for his machine. As i decided i need bigger monitor in the garage. So its still kicking. Meanwhile 2-3 dead expensive laptops, phones, etc. The ones that have "time fuse", when warranty expires, fuse blows
So Dell is the Name.
5 axis desktop machine Kickstarter
By 5AXISMAKER in forum Machine DiscussionReplies: 6Last Post: 24-09-2014, 08:41 PM -
Interesting story
By TonyD in forum General DiscussionReplies: 1Last Post: 12-06-2014, 09:46 PM -
The Nomad CNC Mill on kickstarter
By deadmeat30 in forum Milling Machines, Builds & ConversionsReplies: 19Last Post: 22-05-2014, 11:53 PM -
BT/ISO15 ATC Spindle Cartridge on Kickstarter
By m_c in forum Marketplace DiscussionReplies: 12Last Post: 14-09-2013, 02:15 AM -
Interesting CNC image BLOG ..
By emilvv in forum General DiscussionReplies: 0Last Post: 20-07-2009, 08:29 AM
