Thread: Kopal Milling Clamps
22-08-2016 #6
I've milled the hold-down bolt hole on two of mine out to a slot to take M10 custom bolts but it's a common misconception that the hold down bolts need high torque, they don't.
Kopal clamp hold down screws should be hand tight and not swung on, they only need to be tight enough to stop the clamp easily moving out of position before any clamping force is applied, the tool provided has the right dimensions to stop the uninformed swinging on the screw and applying excessive torque ;-)
The whole point of the design is that applying the clamp uses the hold down bolt as the pivot point of a lever with the work contact and the back end of the clamp as the pressure points.
If you break the screws you're not understanding the correct usage of the clamps :D
Lenzkes Tooling Clamps Qty2 - CNC Milling/Drilling
By mekanik in forum Workshop & EquipmentReplies: 2Last Post: 02-02-2015, 06:47 PM -
MOD 1 rack clamps
By charlieuk in forum Marketplace DiscussionReplies: 3Last Post: 31-01-2014, 09:07 PM -
Hold down clamps, what do you use?
By Web Goblin in forum Machine DiscussionReplies: 16Last Post: 14-04-2012, 11:45 PM -
Clamps
By p1lts in forum General DiscussionReplies: 3Last Post: 27-10-2011, 06:55 PM -
FOR SALE: Pneumatic Clamps
By compfranon in forum Items For SaleReplies: 5Last Post: 07-04-2010, 07:33 PM
