05-05-2016 #9
Little update on the Z and Y cartdesign, after a lot of iterations i'm now converging on a better solution for the design. However there are still changes to make and improve upon, and I hope on some feedback on my design.
A image of the whole thing. With the 100x200mm t=6 steel square tube in the front.
New setup on the stepper motor for the Z axis with a belt and pulley system. The Stepper is also mounted so it's easy to tighten the belt. It's also easy to pluck out of the machine.
The end of the ball screw it fixed with a custom double ball bearing fixture. Using 10mm thick SKF 6201 ball bearings.
Njhussey, after some back and fourth I managed to make space for the Mounting of the Z and Y blocks over each other.
Here is the square tube see-trough so it's possible to see the mounting of the spindle and the ball screw mechanism. I had to make a cut in the square tube from the top to make space for the ball screw. This did not however weaken the rigidity of the Z cartsignificantly.
Cast aluminium gantry router
By jrcast in forum Gantry/Router Machines & BuildingReplies: 17Last Post: 17-02-2017, 08:13 PM -
BUILD LOG: Aluminium Framed Router
By lucan07 in forum DIY Router Build LogsReplies: 34Last Post: 04-05-2016, 09:06 PM -
600 x 400 Aluminium Profile Gantry Router
By Journeyman in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 02-03-2016, 04:28 PM -
RFQ: RFQ: Aluminium parts for my CNC router
By biketrialsdave in forum Projects, Jobs & RequestsReplies: 0Last Post: 12-10-2014, 10:06 PM -
BUILD LOG: Aluminium Extrusion CNC Router Build
By joshendy in forum DIY Router Build LogsReplies: 9Last Post: 10-04-2012, 08:26 PM
