23-06-2016 #51You think that's too expensive? You're not a Model Engineer are you? :D
23-06-2016 #52
I thought selecting a stepper or servo should bee easy, but it seems like nothings easy here. So for each person I ask I get a different recommendation. Steppers, open loop, closed loop, no only servos is good enough. The common thing is that everyone recommends servos if I want to use the money. But they are waaaaaaaaaaay more expensive than normal steppers. And all the cheap servos and closed loop steppers is a pain to get information on, since the datasheets and torque curves is not easily available and I have to ask the sellers for it for every motor. But my logic is as follows, if open loop steppers is good enough for Tormach it's good enough for me. First to comment on how this is not a mill. Then I can use some higher quality steppers instead.
By the way can someone remember the good reason to not use overkill steppers like 8nm nema 34? It's not like they are a lot much more expensive. I read it somewhere but I can't find it.Last edited by PotatoMill; 23-06-2016 at 10:08 PM.
23-06-2016 #53
With nema 34 you will need mains voltage drives to get any decent results You won't go far wrong with decent 23,s from Zapp or CNC4you
With AM882 or similar drives and 68V power supply non linearLast edited by Clive S; 23-06-2016 at 10:59 PM.
23-06-2016 #54
I think Nema 34 steppers would be too large for your machine. The Load/Motor Inertia Ratio would probably be below 1:1 and therefore you're using more energy accelerating the motor shaft than you are accelerating the 40kg load!
I'm not sure about Steppers but for Servos a 5:1 Load to Motor Inertia Ratio is pretty normal, with 2-3:1 being higher performance and even 1:1 is used for super speedy machines.
A belt reduction gives you flexibility in the gear ratio. If you happen to under size the motors you can lower the gearing and get more torque with less speed, but if you over size the motors you can get some free speed!
I'm sure you can see how this becomes a hobby for many people... Haha!
Cheers,
Fenza
26-06-2016 #55
How about fixed screws and rotating ballnuts?
No problems with whip from the screws and reduced rotating mass ;-)You think that's too expensive? You're not a Model Engineer are you? :D
26-06-2016 #56
26-06-2016 #57
26-06-2016 #58
28-07-2016 #59
Do someone have some opinions on this stepper http://www.aliexpress.com/item/Nema-...999.264.8phZye? 1.8mh seems nice, but the seller dont looks so professional.
28-07-2016 #60
Cast aluminium gantry router
By jrcast in forum Gantry/Router Machines & BuildingReplies: 17Last Post: 17-02-2017, 08:13 PM -
BUILD LOG: Aluminium Framed Router
By lucan07 in forum DIY Router Build LogsReplies: 34Last Post: 04-05-2016, 09:06 PM -
600 x 400 Aluminium Profile Gantry Router
By Journeyman in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 02-03-2016, 04:28 PM -
RFQ: RFQ: Aluminium parts for my CNC router
By biketrialsdave in forum Projects, Jobs & RequestsReplies: 0Last Post: 12-10-2014, 10:06 PM -
BUILD LOG: Aluminium Extrusion CNC Router Build
By joshendy in forum DIY Router Build LogsReplies: 9Last Post: 10-04-2012, 08:26 PM
