Thread: pulse equivelant calculation
	25-04-2016 #1
i need help on calculating the pulse equivalent for rack and pinion system and ball screw system....thnx
	25-04-2016 #2
	12-05-2016 #3
hiii i built a cnc router ,i used rack and pinion for the x and y with gear ratio 1:5 and ball screw for the z with gear ratio 1:3 i am ysing a dsp hand controllrer the problem is the distance moved by the machine is not exact like the drawing it is as if it is scaled larger by 10%...there is a setting in the dsp hand that requires a parameter which is the no of pulse needed to move the machiene 1 mm pulse/mm so i guess there is a formula for rack system and another for ballscrew to calculate this parameter..thnx
	12-05-2016 #4
break this down into steps first. Working on Metric system.
#1 Need Shaft Revs per Unit. So need tooth pitch(TP) and number of teeth on Pinion(PT). Shaft Revs per unti = 1 / (TP * PT)
So example working on Mod 1 with 24 Teeth: Shaft revs per unit = 1 / (1 * 24) =0.0416
#2 Motor Revs per unit With Ratio. For this we need number of teeth on Motor (MT) This is Motor Revs per unit = Shaft Revs per unit * PT / MT
Example 0.0416 * 24 / 12 =0.0832
#3 Steps Per Unit= Motor Revs * Microsteps. Example 0.0832 * 2000= 166.40 Steps per
	17-05-2016 #5
Use this calculator:
http://mycnc.co.uk/coding/AxisCalculator.zip
How-To: Feed Rate Calculation
By Lee Roberts in forum Machine DiscussionReplies: 20Last Post: 25-03-2020, 04:09 PM -
Stepper motor Pulse Signal Generator module
By Tom J in forum Motor Drivers & ControllersReplies: 8Last Post: 12-01-2016, 11:47 AM -
My turn for help with Pulse multiplier for test rig.
By JAZZCNC in forum Electronic Project BuildingReplies: 75Last Post: 20-06-2014, 06:09 PM -
MPG or Hand Wheel Pulse Encoder where to buy in UK?
By suesi34e in forum Marketplace DiscussionReplies: 5Last Post: 02-01-2014, 04:41 PM -
Pulse rate or dip switch settings
By Jopo in forum Stepper & Servo MotorsReplies: 0Last Post: 29-04-2013, 08:08 AM
