    hiii i built a cnc router ,i used rack and pinion for the x and y with gear ratio 1:5 and ball screw for the z with gear ratio 1:3 i am ysing a dsp hand controllrer the problem is the distance moved by the machine is not exact like the drawing it is as if it is scaled larger by 10%...there is a setting in the dsp hand that requires a parameter which is the no of pulse needed to move the machiene 1 mm pulse/mm so i guess there is a formula for rack system and another for ballscrew to calculate this parameter..thnx
    break this down into steps first. Working on Metric system.
    #1 Need Shaft Revs per Unit. So need tooth pitch(TP) and number of teeth on Pinion(PT). Shaft Revs per unti = 1 / (TP * PT)
    So example working on Mod 1 with 24 Teeth: Shaft revs per unit = 1 / (1 * 24) =0.0416
    #2 Motor Revs per unit With Ratio. For this we need number of teeth on Motor (MT) This is Motor Revs per unit = Shaft Revs per unit * PT / MT
    Example 0.0416 * 24 / 12 =0.0832
    #3 Steps Per Unit= Motor Revs * Microsteps. Example 0.0832 * 2000= 166.40 Steps per
  1. How-To: Feed Rate Calculation
    By Lee Roberts in forum Machine Discussion
    Last Post: 25-03-2020, 04:09 PM
  2. Stepper motor Pulse Signal Generator module
    By Tom J in forum Motor Drivers & Controllers
    Last Post: 12-01-2016, 11:47 AM
  3. My turn for help with Pulse multiplier for test rig.
    By JAZZCNC in forum Electronic Project Building
    Last Post: 20-06-2014, 06:09 PM
  4. MPG or Hand Wheel Pulse Encoder where to buy in UK?
    By suesi34e in forum Marketplace Discussion
    Last Post: 02-01-2014, 04:41 PM
  5. Pulse rate or dip switch settings
    By Jopo in forum Stepper & Servo Motors
    Last Post: 29-04-2013, 08:08 AM
