Page 2 of 7 FirstFirst 1234 ... LastLast
    Your maths seems good.
    What do you mean you only get a reading of 26?
    What are you actually commanding?
    And do you really mean 550mm?
    if I use the arrow keys on the keyboard to jog the x axis for example. I travel the whole length of the machine which is 550mm as stated in the denford manual but the dro readout in mach only say 128
    so something isn't right
    Lives in East Lothian, United Kingdom. Last Activity: 6 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    So it's out by a factor of 4.something.
    Are you sure the microstepping is 10?
    Easy way to check, is if you mark a motor pulley/screw, then request a move of 3mm, it should rotate one full turn. If it doesn't, then you need to work out why.
    run the auto configuration on the X,Y & Z axis on the settings tab bottom left above reset
    Quote Originally Posted by lucan07 View Post
    im using machstdmill ive no idea how to get it back to normal mach screen set
  6. #16
    I seem to have a recollection of certain drives having the switches the wrong way around, but if that was the case, you'd be out by a far larger factor.
    Run the test like I said, and you'll know for sure if it's the microstep setting causing the numbers to be wrong or not.
    I think you should be able to swap back to the standard screen by simply selecting the standard screen, however I've never used MSM. Regardless, I prefer to calculate the steps manually, as that way I know if something isn't set how it should be, or I've got a number wrong somewhere.
  7. #17
    If you run machloader create a copy of your setup its a good idea to have a standard screen setup to troubleshoot, and you could run autotune.
    Are you sure not mixing Motor tuning and mach default mm's and inches 26x25.4 = 660 would only be 20% out closer than 400%.
  8. #18
    just managed to find and use the autotune which is a great feature.
    but still not right, a full x movement of the table now reads 282, so better but not right.
    some thing is very odd here
  9. #19
    You are using a smoothstepper so that I suspect generates pulses rather than PC, I would look closely at the smoothstepper settings if there is a multiplier or something there, some do for servo's to get up to speed. Some good videos on warp9 for setup I saw when considering the smoothstep
  10. #20
    ok set the drivers to 32 steps and half current
    used the auto tune feature and doing a full x travel I get 550mm, soft limt isn't working for some reason so I need to look into that
  1. FOR SALE: Denford Starmill ATC
    By andy_con in forum Items For Sale
    Last Post: 14-02-2016, 10:16 PM
  2. 1999 Denford Microrouter problems
    By D-man in forum Denford Routers
    Last Post: 21-03-2015, 12:43 PM
  3. Denford MicroRouter Compact, what to do next?
    By paul_m in forum Denford Routers
    Last Post: 08-01-2015, 09:51 AM
  4. FOR SALE: Denford cnc
    By john legge in forum Items For Sale
    Last Post: 17-03-2013, 11:18 PM
  5. Denford CNC MicroRouter
    By mekanik in forum Milling Machines, Builds & Conversions
    Last Post: 27-08-2012, 06:57 PM
