Page 5 of 7 FirstFirst ... 34567 LastLast
  1. #41
    Lives in East Lothian, United Kingdom. Last Activity: 17 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,987. Received thanks 373 times, giving thanks to others 9 times.
    I just googled the stepper motor model number, and it threw up a few different datasheets/catalogues.
    The catalogue for MAE stepper motors is http://www.probyte.fi/pdf/HY200-3424-0170.pdf
    Which confirms the 3A/75V ratings.
    However another datasheet put that exact same model at only 2.1A per phase.
    I can't find any definitive figures for maximum temperature, but up to 80degC seems to be a common recommendation. If you are running the motors below their ratings, I wouldn't worry too much about it.
    If you're not happy with them running that hot, try what Lucan suggests, and drop the current setting further.
  2. #42
    Will drop the current one step
    First bit if work completed
  3. The Following User Says Thank You to andy_con For This Useful Post:
  4. #43
    Ready for painting
  5. The Following User Says Thank You to andy_con For This Useful Post:
  6. #44
    Looking good Andy!
    .Me
  7. The Following User Says Thank You to Lee Roberts For This Useful Post:
  8. #45
    if the motor is 8 wire, then 3A is the unipolar current and 2.1 is in series and it will be 4.2 in parallel. this is typical for 8 wire motors.
  9. #46
    Quote Originally Posted by lucan07 View Post
    No idea what the last post says, as you're not worth talking too certainly not listening too PS theres a goat crossing the bridge!
    Ah ah this Makes a change from me being the one clashing heads but rest assured if I hadn't been busy I'd have blasted you just the same.!! . . .Your very out of order Calling MC a Troll. He's one of the nicest and most helpful people on the forum who's replys are considered and well thought out with healthy dose of common sense applied.
    He's absolutley Correct in what he was saying, Know this because I'm often the one cleaning up when people with little to no experience dish out advice with such authority that unsuspecting people often desparate to resolve problems fall hook line sinker and take it on board. Only to find out that person was full of shit.!!
    Like MC this is also one of my pet hates and like him I'll always jump on people who do this because it's not helping anyone but the Ego of the tosser who's spouting bull shit.!
    Have bit more respect for nice guy and don't be so quick to dishout advise if don't know what your on about.!
    Andy Con.
    I haven't read all the thread so not upto speed but I recently converted a Denford router to mach using exisiting motors but with New digital drives and the motors run at worst just little more than warm while cutting. At stand still they are stone cold.
    All this talk of Controller handling Current reduction is bullshit, 99.9% it's function of the drive that works regardless whether Mach or PC working or not. Drive just sense's for signals and goes into stand by if not recieved any within period of time.
    I'd be checking settings and Motor phase wiring because with only 36v you shoudn't be getting hot. That said how hot is hot did you take temp reading.?
    PS: Nice work on the signs.
  10. The Following User Says Thank You to JAZZCNC For This Useful Post:
  11. #47
    Quote Originally Posted by andy_con View Post
    Andy,
    That all looks great, but have you considered adding a V-carve type path about 4mm deep with a V-bit cutter for the outlines?
    That would give you near pin-sharp corner definition on characters and graphics where they merge and the cutter diameter cannot manage sharp corners,
    Regards,
    Nick
  12. #48
    ive dropped the current to 2.4amps and things are a bit cooler, not had to chance to look into anymore of recent. but it is on my big to do list.
    thanks for the tips
    Andy Con.
  13. #49
    the machine only came with a single 6mm collet so im limited to 6mm shank tools at the moment. ive ordered some more collets from the us which im waiting to arrive, once I get them I can start using more tools.
    that engraving one done with a v-bit router tool, but only 0.3mm deep. were I to have the right collet I would have done it 1mm deep with a 1mm end mill
    im pretty new to wood, so still learning what gives the best results. ive since painted that engraving so its looks much better now
    Andy,
    Regards,
    Nick
  14. #50
    V-Carve paths are 3D and lift the V Bit at the corners to give straight lines/accurate curves right up to any sharp corners,
    Regards,
    Nick
  15. The Following User Says Thank You to magicniner For This Useful Post:
  1. FOR SALE: Denford Starmill ATC
    By andy_con in forum Items For Sale
    Last Post: 14-02-2016, 10:16 PM
  2. 1999 Denford Microrouter problems
    By D-man in forum Denford Routers
    Last Post: 21-03-2015, 12:43 PM
  3. Denford MicroRouter Compact, what to do next?
    By paul_m in forum Denford Routers
    Last Post: 08-01-2015, 09:51 AM
  4. FOR SALE: Denford cnc
    By john legge in forum Items For Sale
    Last Post: 17-03-2013, 11:18 PM
  5. Denford CNC MicroRouter
    By mekanik in forum Milling Machines, Builds & Conversions
    Last Post: 27-08-2012, 06:57 PM
