just managed to find and use the autotune which is a great feature.
but still not right, a full x movement of the table now reads 282, so better but not right.
some thing is very odd here
Quote Originally Posted by lucan07 View Post
If you run machloader create a copy of your setup its a good idea to have a standard screen setup to troubleshoot, and you could run autotune.
Are you sure not mixing Motor tuning and mach default mm's and inches 26x25.4 = 660 would only be 20% out closer than 400%.
