Thread: Denford Microrouter V4
It must of taken a while for you to search for that answer, but it still would not explain why the motors don't warm noticeably after being run for a while.
FWIW Denford used a few different versions of Baldor CNC controllers, but something like a Triac would of most likely used Parker stepper drivers, which from what I remember don't have any kind of current reduction. They're either enabled, or disabled, but commercial machines will rarely disable drives, as you run the risk of losing position during disable/enable.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
04-06-2016 #2
My information comes from IT support,for a while I ran a local authority IT dept including education dept and a few Denford's it was one of the recurring jobs talking numpties through the reset, which is why its remembered.
04-06-2016 #3
for info
Triac
running ESS, PMDX126 and original digi plan drivers, it use nema 43 steppers
there is a home brew board between PMDX and digi plan driver which came with the machine
microrouter
running ESS, BOB and drivers as linked to at the start of this thread.
steppers in the microrouter
stepper drivers are running on 36v and set to 2.8amps
04-06-2016 #4
Andy, any idea what current the original drivers were set at?
Regardless, it looks like you're running the motors within their ratings, so I wouldn't worry about it too much. You could probably drop the current a little bit more if you're concerned, but it really depends on how conservatively or hard you want to run things.
One thing that I keep wondering about, is why the microstepping setting never worked how it should. If it was because the DIP switch was faulty, then the current setting could also be an issue.
It's probably not a fault, but was the step per setting a problem for all axis?
And are all the steppers getting equally warm?
Lucan, even at that, you keep posting what sound like definitive solutions without getting all the facts, which could quite easily cause more problems than they solve.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
04-06-2016 #5
How can it sound like a definitive solution when we were talking about a Triac that has no problem?
FOR SALE: Denford Starmill ATC
By andy_con in forum Items For SaleReplies: 1Last Post: 14-02-2016, 10:16 PM -
1999 Denford Microrouter problems
By D-man in forum Denford RoutersReplies: 5Last Post: 21-03-2015, 12:43 PM -
Denford MicroRouter Compact, what to do next?
By paul_m in forum Denford RoutersReplies: 2Last Post: 08-01-2015, 09:51 AM -
FOR SALE: Denford cnc
By john legge in forum Items For SaleReplies: 4Last Post: 17-03-2013, 11:18 PM -
Denford CNC MicroRouter
By mekanik in forum Milling Machines, Builds & ConversionsReplies: 12Last Post: 27-08-2012, 06:57 PM
