Thread: Milling Slots - Noob question
04-05-2016 #2
If the slot dimension is critical you might find it a little over size, if I needed a slot bang on 6mm I'd use a 5mm cutter.
The single flute carbide cutters are magnificent, I've done a lot of aluminium profiling with one using just air, with light cuts it keeps the cutter cool enough, I use a compressor and regulate the pressure to give the flow I need to clear the chips.
To direct the air onto the work I use a length of clip-together coolant tube with a canula needle epoxied into the end of the nozzle, I ground the end of the needle off square for safety.
I have a drip feed to introduce lubricant into the air flow which helps with aluminium and is essential with stainless ;-)
Vacuum will need a shoe over the work to lift chips out of a deep slot, if you had a 100% hard vacuum then you still only have atmospheric pressure working for you, about 14psi.
Any tips for deep slots/profiling in aluminium?
By m_c in forum Metalwork DiscussionReplies: 9Last Post: 18-04-2014, 12:00 AM -
NEW MEMBER: Noob
By Karl CNC Scenex in forum New Member IntroductionsReplies: 7Last Post: 20-12-2012, 11:16 AM -
NEW MEMBER: noob log in...
By flez1966 in forum New Member IntroductionsReplies: 2Last Post: 12-10-2009, 06:33 AM -
NEW MEMBER: Another Noob!
By Jaff in forum New Member IntroductionsReplies: 3Last Post: 16-09-2009, 10:46 PM -
making very fine slots...
By irving2008 in forum Machine DiscussionReplies: 5Last Post: 09-09-2009, 01:11 AM
