  1. #2
    If the machine doesn't have Home switches then just jog the machine to location you want to call MACHINE ZERO then push Ref All Home. This Zero's the Machine coordinates DRO's. To see this click on Machine Coord's Button under axis DRO's and they should all be Zero.
    Now To set WORK Zero Jog machine to location you want Work Zero then push ZeroX , ZeroY, ZeroZ. This sets your work Origin.
    If you still have the Machine Coord's button pressed you'll see numbers in there now. If you turn Machine Coord's button off you'll see the Axis are Zero.
    This is the Offset between Machine Origin and Work Origin.
  1. site setting fairy hard at work again?
    By m_c in forum General Discussion
    Last Post: 21-05-2014, 04:53 PM
  2. Any backlash setting needed for ballnut endowed machine?
    By HankMcSpank in forum Lead Screws, Nuts & Supports
    Last Post: 14-09-2013, 12:00 AM
  3. Need help setting up a CNC router machine please
    By 1albobs in forum Gantry/Router Machines & Building
    Last Post: 27-02-2012, 06:16 PM
  4. Help with setting up my cnc and engraving machine's
    By soyeb in forum General Discussion
    Last Post: 30-05-2011, 11:51 AM
  5. Setting up work on the rotary table
    Last Post: 09-01-2010, 10:27 AM
