Thread: Laser Upgrade
Just to engrave cut paper cloth and leather etc I use a 2.8w unit from aliexpress but would be slow in CNC router, I just knocked up a 2 axis nema17 driven unit with Ramps 1.4 and Arduino Mega 2560 including bearings etc under £200 runs Repetier firmware and software code produced straight out of inkscape. The laser comes with TTL driver 0-5v control same seller I got mine from good enough to engrave and simple to wire use 0-5v supply same as spindle 0-10v setup.
mine http://www.aliexpress.com/item/REAL-...00009.1.33k3rt
06-05-2016 #2
My router is pretty quick as it is using rack and pinion for the X and Y axis - I really dont want to have to buy another machine as I need the z-axis (I think) to achieve what I want to...
this video is what I'm looking to try...... https://www.youtube.com/watch?v=rUIrS3Ot1I4 I've got no doubt that my machine could go quicker than that too.
06-05-2016 #3
You could strap a laser diode to your machine and use the PICengrave software as shown in the video. Two things come to mind though: Extraction and air blast. MDF and wood, smoke when being etched, you will need to have a good extractor fan and some sort of hood. The air blast ensures the laser lens stays clean but also that your piece does not catch fire. All doable, just remember, do not stare into the laser with your one remaining eye :D
https://emvioeng.com
06-05-2016 #4
The impressive video of a 150w Co2 laser is worlds away of anything will be achieved by a 2-10w diode.
06-05-2016 #5https://emvioeng.com
Newbie - Help With Laser Cutting Speed And Power - 60W Laser
By nickpscott in forum Laser Machines & BuildingReplies: 2Last Post: 11-11-2015, 10:07 PM -
FOR SALE: K40 laser not working (laser fires)
By calida in forum Items For SaleReplies: 0Last Post: 31-03-2015, 08:45 PM -
advise options needed on laser upgrade/add on
By george uk in forum Laser Machines & BuildingReplies: 9Last Post: 19-07-2014, 10:54 PM -
WANTED: GCc Laser Pro or Epilog Laser Cutter Machine
By Brownhills school in forum Items WantedReplies: 1Last Post: 10-05-2012, 04:30 PM -
Upgrade
By Dopy in forum General DiscussionReplies: 0Last Post: 09-11-2011, 01:57 AM
