Thread: ebay power supply
The power supply has two modes of operation:
Variable, where the output is controlled by a voltage applied to pin 28 (i/Ucr) on the main connector. This control voltage is to be set somewhere between 5V and 11V.
Fixed, if voltage applied to pin 28 is lower than 5V or above 11V the power supply output is fixed to 42.8 (+/- 0.5V). It appears that leaving pin 28 unconnected is sufficient to force the supply into fixed mode.
The resistor pair (R33, R34) provide the feedback voltage used when in fixed mode. I think, but never did prove, the resistor pair (R11, R12) provides the feedback voltage when in variable mode. All comments from this point on will assume fixed mode is selected.
Without modification the R33, R34 pair act as a x10 divider so whatever the voltage at the output one tenth of that voltage appears at the junction of R33, R34. The PSU is designed to hold the voltage at this junction at 4.28 volts.
For a given output voltage the R33, R34 pair are chosen such that 4.28 volts appears at the point where they join.
For an output of 24V, R34 must drop (24 - 4.28 =) 19.72V, leaving 4.28 volts across R33. Leaving R33 at 1k this would give us a value of 4k6 for R34.
Without modification the current through R33, R34 = 42.8 / (9k1 + 1k) = 4.28mA. The power dissipated by R33 = 4.28V * 0.00428A = 0.018W and the power dissipated by R34 = 38.52V * 0.00428A = 0.165W (so why do they use such a chunky resistor for R34 ?)
For a 1k + 4k6 24V modification the current through R33, R34 = 24 / (4k6+ 1k) = 4.29mA. The power dissipated by R33 = 4.28V * 0.00429A = 0.018W and the power dissipated by R34 = 19.72V * 0.00429A = 0.085W (most resistors/multi-turns would appear ok, but keep a close eye on the temperature of the multi-turn)
Another thing to look out for is ripple, how much the output voltage varies as the switch mode switches. Indeed, the minimum duty cycle of the switching circuit may even limit the minimum voltage to something greater than 24V. Only testing will tell.
Finally. Beware of the 400 Volt lines!!!
14-04-2012 #2
I bought three of these 500W 50.5V power supplies for £12 way back in 2009.. as time has passed I mislaid the documentation.. A google search Found the missing PDF here. My Lazy way of solving this problem was to buy three 20 Amp bridge rectifiers to limit the output Voltage to Less than 50V therefore solving the slightly higher than 50v output.
My reason for this solution is messing with switch mode PSUs is quite dangerous. (a friend of mine was hit in the temple by a flying electrolytic case when delving into a switch mode psu. With such force it caused a tear in his retina.)
Your circuit hacking/reverse engineering provides a more elegant solution thank you.
Is their any reason why my "Lazy solution" of 2 x the diode volt drop was not considered as a solution in regulated mode?
14-04-2012 #3
Good question, I think at the time my list of solutions looked like:
Plan A
Modify existing circuit.
Plan B
There should always be space for a plan B even if it lacks a concrete definition ;)
Plan C
As the required voltage drop is small use one or more semi-conductor junctions (diodes or transistors)
Plan A
The PSUs were quite cheap so it didn't really matter if I blew one up. In fact the 'spare parts' alone would be worth more than £12.
I had two PSUs to play with, potentially losing one was not a problem. In fact I did lose one, I left it in the office and forgot to bring it home when the company closed down - Grrrr
The whole idea of switch-mode PSUs is to efficiently convert one voltage to another. Modification is the correct solution.
After all that, any modification had to be as simple as possible, as safe as possible and not involve anything near the high voltage side.
Should only be attempted by those who are aware of and acknowledge and are are happy with the risks involved in opening a SMPS
Plan B
Very simple solution.
Does not involve opening the PSU
Safe to implement but in use this sense of safety is somewhat deceptive:
1) The forward voltage (Vf) drop of a semiconductor junction (diode) is not a fixed value. Buy rule of thumb we often assume something around 0.6v, 0.7v but look at the datasheet for the device you intend to use and you may find that Vf = 0.7V at 1A but up to Vf = 1.0V at 10A and as low as 0.4V at <0.1A. So two diodes in series may give you a 1.4V drop or they may give you a 2.0V drop or a 0.8V drop - over 50% variation depending on current draw. Whether or not this matters is entirely down to what you are trying to achieve, but I'm sure some bright spark is certain to attempt to use 10 to 15 diodes in series for 7V to 10V drop - well, at 50% or more variation this is when the magic smoke can escape.
2) Heat! If each semiconductor junction drops 1V at 10A draw then each and every semiconductor junction will dissipate 10W at 10A draw, for continuous use we now need heatsinks and possibly insulation.
That covers most of the risk / reward assesment. Two diodes are great if you've done your homework and everything checks out, in my case I was happier making the mod :)
14-04-2012 #4
Cool.. I was trying to imagine some reason I had not thought of.
The devices in question were KBPC5010, I was wrong saying they were 20A it was 50A.
With FVD variation <0.5v over the current range 0-10A. (0.5v to 1v)
They will now be put to one side for my next Green energy project.
can I have my power supply in a seperate box?
By nobby in forum General ElectronicsReplies: 1Last Post: 12-06-2013, 11:33 PM -
Minimal-cost Power Supply Strategy - Repurpose Laptop Power Supplies
By LoveLearn in forum General ElectronicsReplies: 0Last Post: 25-01-2012, 09:29 PM -
FOR SALE: 50V 20A Power supply
By Jimmybristol in forum Items For SaleReplies: 8Last Post: 30-05-2011, 11:01 PM -
12V Fan off 230v power supply ?
By Buba b in forum General ElectronicsReplies: 5Last Post: 02-03-2010, 09:51 PM -
power supply
By hitmythumb in forum General ElectronicsReplies: 6Last Post: 21-06-2009, 10:27 AM
