Thread: ebay power supply
14-04-2012 #31
Good question, I think at the time my list of solutions looked like:
Plan A
Modify existing circuit.
Plan B
There should always be space for a plan B even if it lacks a concrete definition ;)
Plan C
As the required voltage drop is small use one or more semi-conductor junctions (diodes or transistors)
Plan A
The PSUs were quite cheap so it didn't really matter if I blew one up. In fact the 'spare parts' alone would be worth more than £12.
I had two PSUs to play with, potentially losing one was not a problem. In fact I did lose one, I left it in the office and forgot to bring it home when the company closed down - Grrrr
The whole idea of switch-mode PSUs is to efficiently convert one voltage to another. Modification is the correct solution.
After all that, any modification had to be as simple as possible, as safe as possible and not involve anything near the high voltage side.
Should only be attempted by those who are aware of and acknowledge and are are happy with the risks involved in opening a SMPS
Plan B
Very simple solution.
Does not involve opening the PSU
Safe to implement but in use this sense of safety is somewhat deceptive:
1) The forward voltage (Vf) drop of a semiconductor junction (diode) is not a fixed value. Buy rule of thumb we often assume something around 0.6v, 0.7v but look at the datasheet for the device you intend to use and you may find that Vf = 0.7V at 1A but up to Vf = 1.0V at 10A and as low as 0.4V at <0.1A. So two diodes in series may give you a 1.4V drop or they may give you a 2.0V drop or a 0.8V drop - over 50% variation depending on current draw. Whether or not this matters is entirely down to what you are trying to achieve, but I'm sure some bright spark is certain to attempt to use 10 to 15 diodes in series for 7V to 10V drop - well, at 50% or more variation this is when the magic smoke can escape.
2) Heat! If each semiconductor junction drops 1V at 10A draw then each and every semiconductor junction will dissipate 10W at 10A draw, for continuous use we now need heatsinks and possibly insulation.
That covers most of the risk / reward assesment. Two diodes are great if you've done your homework and everything checks out, in my case I was happier making the mod :)
can I have my power supply in a seperate box?
By nobby in forum General ElectronicsReplies: 1Last Post: 12-06-2013, 11:33 PM -
Minimal-cost Power Supply Strategy - Repurpose Laptop Power Supplies
By LoveLearn in forum General ElectronicsReplies: 0Last Post: 25-01-2012, 09:29 PM -
FOR SALE: 50V 20A Power supply
By Jimmybristol in forum Items For SaleReplies: 8Last Post: 30-05-2011, 11:01 PM -
12V Fan off 230v power supply ?
By Buba b in forum General ElectronicsReplies: 5Last Post: 02-03-2010, 09:51 PM -
power supply
By hitmythumb in forum General ElectronicsReplies: 6Last Post: 21-06-2009, 10:27 AM
