I will leave it to those with more experience to advise you but personally I wouldn't dream of spending £1000 on a machine that I could build better for same money, I looked at many and decided to design/build my own and as a result I have a mill converted for £680 including new purchase price I used for my build (I did not like idea of extrusion personally), and a Router with 750x420x100mm work area 2.2kw VFD and spindle, extremely solid 12mm DOC in MDF 1/4" bit at 1500mmpm and had plenty left, and £1000 covers everything even pricing aluminium at the Ali Warehouse as I got most of it very cheaply. Add in my Mach3 Licence and I am still well under £2000 with two machines working well and doing all I require, if you use extrusion you would not need the mill and even cheapest supported rails would be better than the unsupported ones I believe these come with looking at site. I would offer him £300 and take a chance but once I got near cost of a half decent build I would run!
06-05-2016 #2
Hi
I have the 720 which is less than a year old and i like it for what i do but it has not come without problems.
If you search for my posts you can catch up with the problem i have regarding speed and yes the cost implication of getting the screw sorted is high. I now run at a much lower speed and get some great results but as Jazzcnc and others will tell you for the money i paid it should be running a hell of a lot quicker. As i cant afford to build or get another model i live with this restriction so my advice is definitely dont over drive it, if you cant live with low speed for whatever reason then its not going to be much cop for you i imagine.
I use WinPCNC which when i ran the setup all the default settings are there, i dont know what you will use but if i can give you a setting or 2 i will try.
I am a novice so would not give you advice thats really for the experts i just hope this adds a bit of info for you
BernieLast edited by BernieNUFC; 06-05-2016 at 08:21 PM. Reason: spelling
08-05-2016 #3
Rusty rails and old PCs need replacing, then you need to get the thing running which could involve more new hardware and possibly software too.
It's not worth more than the second hand value of the parts once stripped, as that's what you'll end up with if you can't make it work properly.
08-05-2016 #4
Give it a Miss your buying trouble
09-05-2016 #5
Rusty is going a bit far for describing the rails. There wasn't any red-brown rust, just the spider-web black lines showing where corrosion had started.
I have got the machine for another two weeks at least, so will see what I can coax from it but I am coming around to your way of thinking, that it could be more trouble than its worth, or that it will still be worth more to its current owner than it will be to me.
There are a limited number of things that I have wanted to do on a CNC for a long time, but they are still a limited number, and I am not sure that I would ever manage to do enough to make it pay any significant contribution to its own cost. Simply working on it and the CAD/CAM is somewhat addictive, and I have a long list of other build projects that I should be working on....like turning the stack of 3m joists that have decorated one side of my dining room for nearly three years into a carpenters work bench! When Lucan07 suggested building a better machine, I thought about that pile of timber and the relative complexity of bolting a bench together vs construction of a precision power tool + wiring a computer interface. LOL!
I am still enthusiastic about CNC and its hard to keep reining that in to think about such a tool purchase in a rational manner. Thanks for helping!!!!!
09-05-2016 #6
My build totalled less than £1000 at full price from online suppliers I did grab a few bargains along the way I have spent under £800, I am currently using MDF Base 75mm thick top as an alternative to carrying almost half a ton of steel and cast iron upstairs (The base I designed my router for stored for later use). If materials brought cut to size from somewhere like Ali Warehouse or using Extrusion as many do there is little need for machining plenty of drilling and tapping, although a chop saw with fine tooth tungsten blade cuts aluminium reasonably well. Have been machining Aluminium as easy as on my converted Mini Mill as for the wiring and PC interface is quite simple plenty of documentation and help available in forums.
2008 EM 1325 CNC router
By jegg in forum Chinese MachinesReplies: 2Last Post: 28-01-2016, 11:19 PM -
High-Z/Rhonmac
By Mamba in forum Heiz CNC RoutersReplies: 4Last Post: 02-06-2015, 07:46 PM -
Enter to win $250 Tools gift Cards
By jforrest33 in forum General DiscussionReplies: 0Last Post: 31-07-2014, 10:30 PM -
NEW MEMBER: Beginning machine shop needs help with CNC Step High Z S400 Problems
By NorthernLightsMachines in forum New Member IntroductionsReplies: 2Last Post: 24-07-2011, 09:41 AM -
MACH 2008
By Lee Roberts in forum General DiscussionReplies: 5Last Post: 05-10-2007, 09:48 AM
