Thread: ATC Options?
09-05-2016 #11
Thanks John, thats a neat idea but my mill is very compact and not really enough space to mount two spindles.
I will consign the ATC idea to the bin - it was just a luxury really, very impressive but a luxury still, oh well...
09-05-2016 #12
09-05-2016 #13
Thanks for the link, interesting kit but I need the spindle as well, it seems easy in the 0 to 6000 rpm range but i'm in the 6000-24000 rpm range and then things get ££££ really quickly.
09-05-2016 #14
09-05-2016 #15
Issues i see there...
Not sure a belt will work at 24,000rpm,
The spindles suitable for ATC use are all rated to 6000rpm only it seems, that means special bearings and balancing would be needed for that sort of speed.
10-05-2016 #16
Andy, That PDB has an impact wrench and a pneumatic actuator inside so is only suitable for screw in drawbars. For ATC at 24000, you need a totally different direct drive spindle such as those seen on Alibaba.
They should be balanced but I dare say that the tooling you get will not be.Last edited by komatias; 10-05-2016 at 02:43 PM.
https://emvioeng.com
11-05-2016 #17
im well aware how that drawbar I posted operates, the original post said cheap so I was just posting a cheap option.
11-05-2016 #18
No worries here ;) thanks for the thought.
It does seem that it's a non-starter at present due to the spindle speed I have.
I am now looking towards a bigger machine, maybe converting my Bridgeport or finding a donor with duff electrics that was built for CNC.
11-05-2016 #19
do you need such a high spindle speed?just think a large machine like a haas has an 8-10k spindle speed with bucket loads of torque and that can cut fast and deep. its not all about spindle speed but machine strength and torque. so could you get away with a slower but more powerful spindle?
11-05-2016 #20
Possibly, but this was built for small cutters in aluminium, small cutters are best in carbide, carbide likes high speeds, sort of horses-for-courses really.
I am sure my stuff can be done in HSS but not calculated the feeds, I will have a look.
Engraving really does need speed I think though??
Linear bearing upgrade options?
By Joe in forum Rails, Guideways & BearingsReplies: 10Last Post: 04-03-2015, 09:22 PM -
Profile Cutting Options BobCAD CAM
By aldepoalo in forum BobCAD-CAMReplies: 4Last Post: 25-06-2013, 09:10 PM -
options for 3020 router spindle?
By arborealad in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 19-11-2012, 10:13 PM -
water cooling options for spindle
By routercnc in forum Tool & Tooling TechnologyReplies: 24Last Post: 12-02-2012, 11:22 PM -
Machine rebuild time - options...
By CraftyGeek in forum Gantry/Router Machines & BuildingReplies: 28Last Post: 19-10-2011, 10:26 PM
