Thread: ATC Options?
    Lives in East Lothian, United Kingdom. Last Activity: 1 Day Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    The spindle is the hard part.
    Quite a few people use the Tormach system (TTS), which I think is essentially a modified R8 spindle/collet setup.
    You could go for a conventional ISO/BT spindle with a drawbar, and attach an airgun for loosening/tightening the drawbar.
    Best option is some form of ISO/BT gripper spindle, but they are expensive. I'm sure I've seen ISO30 ATC spindles for around £800, however you need to add a motor to that.
    I still have a DaleCNC ISO15 spindle cartridge sat in the workshop doing nothing if you're interested. It cost me about $1200, but I'm open to sensible offers as I've currently got no plans to use it on anything.
    its not too bad at the low speed end but my spindle is a 24,000rpm water cooled job, my machine was built for aluminium really so it needs the speed. Looking at £1600-£2300 on Aliexpress :(
    I saw this skyfire cnc cartridge a while back. I don't know if it was ever launched - there was quite a thread on cnczone but it wasn't clear if they ever shipped anything. Pretty cheap, although needs a motor and an air cylinder on the drawbar, and is 6000rpm max.
    http://www.skyfirecnc.com/picshow.asp?id=24
    Yep, plenty similar on Aliexpress, BT30, ISO25 sockets but all are low rpm so not really what i was after :)
    There is a German company that does them for Kress and watercooled spindles http://www.sorotec.de/shop/Spindles/...ME-800-V2.html
    https://emvioeng.com
    Then you are going to struggle as once you go bigger on diameter to take a QC taper the bearings needed won't hold up to 24K
    If you can get away with just two tools, roughing and finishing then think about another 24K spindle mounted on another set of rails on the Z axis that can pneumatically push the second cutter down lower than the roughing cutter. Software then calls up the respective offsets and runs the second spindle.
    You can get a completer second spindle and inverter for as low at £175 on Ebay.
    John S -
    Thanks John, thats a neat idea but my mill is very compact and not really enough space to mount two spindles.
    I will consign the ATC idea to the bin - it was just a luxury really, very impressive but a luxury still, oh well...
    Thanks for the link, interesting kit but I need the spindle as well, it seems easy in the 0 to 6000 rpm range but i'm in the 6000-24000 rpm range and then things get ££££ really quickly.
    but that's the point of that powered draw bar, fit whatever spindle motor you want. providing the actual spindle it belt drive that powered draw bar will work
  1. Linear bearing upgrade options?
    By Joe in forum Rails, Guideways & Bearings
    Last Post: 04-03-2015, 09:22 PM
  2. Profile Cutting Options BobCAD CAM
    By aldepoalo in forum BobCAD-CAM
    Last Post: 25-06-2013, 09:10 PM
  3. options for 3020 router spindle?
    By arborealad in forum Milling Machines, Builds & Conversions
    Last Post: 19-11-2012, 10:13 PM
  4. water cooling options for spindle
    By routercnc in forum Tool & Tooling Technology
    Last Post: 12-02-2012, 11:22 PM
  5. Machine rebuild time - options...
    By CraftyGeek in forum Gantry/Router Machines & Building
    Last Post: 19-10-2011, 10:26 PM
