Thread: ATC Options?
Possibly, but this was built for small cutters in aluminium, small cutters are best in carbide, carbide likes high speeds, sort of horses-for-courses really.
I am sure my stuff can be done in HSS but not calculated the feeds, I will have a look.
Engraving really does need speed I think though??
11-05-2016 #2
Interesting,
Just calculated the speeds for a 2mm cutter in 6061T6 and it seems I am seriously under-using carbide anyway.
In Carbide, at full speed it needs 82,000rpm, HSS wants 23,000rpm
The reason I had not seen the high speed before was because I limited HSMAdvisor to calculate feeds based on my limit of 24,000rpm, removing this limit shows the full feed & speeds.
Anyone got an 82,000rpm spindle? :)
Anyway, HSS will do the job at say 6000rpm but it will be much slower.
11-05-2016 #3
Should that be "Unless your'e using large tools" there Jazz?? :)
13-05-2016 #4
My denford triac has a 4k spindle and I don't have any problems.
I do 2mm deep cuts using an 8mm cutter at f250
13-05-2016 #5
14-05-2016 #6
I stand corrected ;)
Yes, speed is needed, it can be done on a slow machine - i've used 1/16" on the old bridgeport before but the feed rate is microscopic!
The high speed spindle is very useful.
Linear bearing upgrade options?
By Joe in forum Rails, Guideways & BearingsReplies: 10Last Post: 04-03-2015, 09:22 PM -
Profile Cutting Options BobCAD CAM
By aldepoalo in forum BobCAD-CAMReplies: 4Last Post: 25-06-2013, 09:10 PM -
options for 3020 router spindle?
By arborealad in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 19-11-2012, 10:13 PM -
water cooling options for spindle
By routercnc in forum Tool & Tooling TechnologyReplies: 24Last Post: 12-02-2012, 11:22 PM -
Machine rebuild time - options...
By CraftyGeek in forum Gantry/Router Machines & BuildingReplies: 28Last Post: 19-10-2011, 10:26 PM
