Thread: ATC Options?
11-05-2016 #21
Interesting,
Just calculated the speeds for a 2mm cutter in 6061T6 and it seems I am seriously under-using carbide anyway.
In Carbide, at full speed it needs 82,000rpm, HSS wants 23,000rpm
The reason I had not seen the high speed before was because I limited HSMAdvisor to calculate feeds based on my limit of 24,000rpm, removing this limit shows the full feed & speeds.
Anyone got an 82,000rpm spindle? :)
Anyway, HSS will do the job at say 6000rpm but it will be much slower.
Linear bearing upgrade options?
By Joe in forum Rails, Guideways & BearingsReplies: 10Last Post: 04-03-2015, 09:22 PM -
Profile Cutting Options BobCAD CAM
By aldepoalo in forum BobCAD-CAMReplies: 4Last Post: 25-06-2013, 09:10 PM -
options for 3020 router spindle?
By arborealad in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 19-11-2012, 10:13 PM -
water cooling options for spindle
By routercnc in forum Tool & Tooling TechnologyReplies: 24Last Post: 12-02-2012, 11:22 PM -
Machine rebuild time - options...
By CraftyGeek in forum Gantry/Router Machines & BuildingReplies: 28Last Post: 19-10-2011, 10:26 PM
