Thread: ATC Options?
    Should that be "Unless your'e using large tools" there Jazz?? :)
    Nope said correctly Andy said Speed wasn't required. I Said "Unless using small tools" Then speed is required.
    Quote Originally Posted by andy_con View Post
    My denford triac has a 4k spindle and I don't have any problems.
    I do 2mm deep cuts using an 8mm cutter at f250
    Compared to me doing 4mm Doc at F900. 11000rpm!! . . . . BIG DIFFERENCE. . . Oh and that's on Router not a Mill.!
    I stand corrected ;)
    Yes, speed is needed, it can be done on a slow machine - i've used 1/16" on the old bridgeport before but the feed rate is microscopic!
    The high speed spindle is very useful.
  1. Linear bearing upgrade options?
    By Joe in forum Rails, Guideways & Bearings
    Last Post: 04-03-2015, 09:22 PM
  2. Profile Cutting Options BobCAD CAM
    By aldepoalo in forum BobCAD-CAM
    Last Post: 25-06-2013, 09:10 PM
  3. options for 3020 router spindle?
    By arborealad in forum Milling Machines, Builds & Conversions
    Last Post: 19-11-2012, 10:13 PM
  4. water cooling options for spindle
    By routercnc in forum Tool & Tooling Technology
    Last Post: 12-02-2012, 11:22 PM
  5. Machine rebuild time - options...
    By CraftyGeek in forum Gantry/Router Machines & Building
    Last Post: 19-10-2011, 10:26 PM
