Thread: 4 pin extension leads
I was going to recommend Audiospares Derby, but just found out they went belly up last year.
Amazon do them https://www.amazon.co.uk/BQLZR-Silve.../dp/B00IJ673ZW
If you can wait for delivery - http://www.aliexpress.com/item-img/10pcs-lot-Silver-Metal-Aviation-Plug-Panel-Power-Chassis-Male-Female-Wire-GX16-4-Pin-16mm/32528830022.html?spm=2114.10010108.1000017.2.5oYF2 8
10-05-2016 #2
Hi All,
Thanks for the information, I found the correct plugs and sockets on ebay.
Gary
16-08-2016 #3
Hi...i think its not such a big issue. Easily you can find that type of cable anywhere. Try from local store or you can try it online also. If still you will not be able to find it then go for building it by yourself. Just take a ribbon wire with you and some connectors and you can build it.
pcb component assemblyLast edited by RobertBil; 20-09-2016 at 07:13 PM.
25-10-2017 #4
PCBA
.GD4 file extension ?
By greenz123 in forum CAD & CAM SoftwareReplies: 7Last Post: 30-06-2015, 12:44 PM -
sales leads
By neilneil in forum General DiscussionReplies: 0Last Post: 12-04-2015, 11:20 PM -
File upload problems - attachments file extension support !
By Swarfing in forum General DiscussionReplies: 14Last Post: 08-03-2013, 02:37 PM -
Heavy Duty Extension Spring
By Stevetechguy in forum Manufacturer NewsReplies: 0Last Post: 17-10-2012, 04:45 PM -
Limiting unsupported extension on Zaxis.
By Rogue in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 03-09-2011, 12:30 AM
