    Hi Wal
    glad to see they are cleaning up OK.
    Try this
    http://www.arcritepaints.com/proxl-p...vings-23-p.asp
    can't emphasize enough that you need etch primer on zink/ally/galvo/ect.
    Hope that is of some help.
    Mike
    Wal's Avatar
    Lives in Stockport, United Kingdom. Last Activity: 15-12-2024 Has been a member for 9-10 years. Has a total post count of 491. Received thanks 71 times, giving thanks to others 29 times.
    Cheers Mike,
    I've got a couple of the handles re-primed with the conventional primer, they smoothed out nice this time around, so I'm hoping for a better gloss finish. Never come across etch primer before - I may end up using it before this job's done, thanks for the link!
    Wal.
    Aerosol paints are a pain in that they tend to be very low in viscosity, that makes the difference between a "wet coat" which will achieve a flat surface and "running off onto the floor" a very fine line to tread ;-)
    +1 on etch for non-ferrous metals
    Argh Painting.!!! That why I bought plastic coater.?. . . . Now every thing gets plastic coated. .
    Wal's Avatar
    Quick update on this - I stuck with the regular non-ferrous primer (as I have a couple of cans of the stuff) and made sure that I rubbed it down properly with an old sock to knock the dusty texture off the primer coat. Then it was 2 light coats of black gloss followed by one slightly heavier coat - now I'm totally getting what Magicniner was saying in his post on the previous page... You've really got to watch for that fine line between the paint building up into a layer just thick enough to give you a glossy coat - too much more after that and I can see that it would have run. Luckily I was paying attention and the finish came out pretty sweet...
ID:	18498 Click image for larger version.
ID:	18497 Click image for larger version.
    Lives in Marple Stockport, United Kingdom. Last Activity: 10 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,346. Received thanks 618 times, giving thanks to others 87 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    As usual Wal another nice job well done
    But don't you think Clive the Screw slots being arranged Vertical to follow the lines of the handle sides would be nicer touch. . . . Great job Wal and nice shine.
  1. Advice needed on everything
    By chrisjames in forum General Discussion
    Last Post: 11-11-2015, 11:40 PM
  2. Advice needed on Amadeal
    By croy in forum General Discussion
    Last Post: 21-08-2015, 01:28 PM
  3. VMC Tooling Advice Needed!
    By cncJim in forum Milling Machines, Builds & Conversions
    Last Post: 03-09-2014, 09:17 AM
  4. Quick Advice Needed - F&S
    By Tenson in forum Tool & Tooling Technology
    Last Post: 01-01-2013, 06:38 PM
  5. SPG X3 CNC Mill, advice needed please
    By shaggyhawkings in forum Milling Machines, Builds & Conversions
    Last Post: 07-01-2010, 11:00 PM
