    Wal's Avatar
    Cheers Mike,
    I've got a couple of the handles re-primed with the conventional primer, they smoothed out nice this time around, so I'm hoping for a better gloss finish. Never come across etch primer before - I may end up using it before this job's done, thanks for the link!
    Wal.
    Aerosol paints are a pain in that they tend to be very low in viscosity, that makes the difference between a "wet coat" which will achieve a flat surface and "running off onto the floor" a very fine line to tread ;-)
    +1 on etch for non-ferrous metals
    Argh Painting.!!! That why I bought plastic coater.?. . . . Now every thing gets plastic coated. .
    Wal's Avatar
    Quick update on this - I stuck with the regular non-ferrous primer (as I have a couple of cans of the stuff) and made sure that I rubbed it down properly with an old sock to knock the dusty texture off the primer coat. Then it was 2 light coats of black gloss followed by one slightly heavier coat - now I'm totally getting what Magicniner was saying in his post on the previous page... You've really got to watch for that fine line between the paint building up into a layer just thick enough to give you a glossy coat - too much more after that and I can see that it would have run. Luckily I was paying attention and the finish came out pretty sweet...
ID:	18498 Click image for larger version.
ID:	18497 Click image for larger version.
    As usual Wal another nice job well done
    But don't you think Clive the Screw slots being arranged Vertical to follow the lines of the handle sides would be nicer touch. . . . Great job Wal and nice shine.
    Yes I do then it would also match the grain on the door. I will have a word with him the next time we meet up.
  1. Advice needed on everything
    By chrisjames in forum General Discussion
    Last Post: 11-11-2015, 11:40 PM
  2. Advice needed on Amadeal
    By croy in forum General Discussion
    Last Post: 21-08-2015, 01:28 PM
  3. VMC Tooling Advice Needed!
    By cncJim in forum Milling Machines, Builds & Conversions
    Last Post: 03-09-2014, 09:17 AM
  4. Quick Advice Needed - F&S
    By Tenson in forum Tool & Tooling Technology
    Last Post: 01-01-2013, 06:38 PM
  5. SPG X3 CNC Mill, advice needed please
    By shaggyhawkings in forum Milling Machines, Builds & Conversions
    Last Post: 07-01-2010, 11:00 PM
