27-11-2016 #281
Ok, what sort of acceleration should i be aiming for if i have a top speed of 3500mm/min and bearing in mind this is a Bridgeport with a fairly heavy table;)
27-11-2016 #282
27-11-2016 #283
Ok, i'll try upping it but it would not stall - it has some fairly big AC servo's on it and a 2:1 reduction so damage would occur first i think or drive shut-down maybe.
27-11-2016 #284
Ok forgot you have servos But same applies really however instead of stalling you'll get position errors or drive trips.! . . . You'll know if OTT
27-11-2016 #285
Ok I'll dive in tomorrow night, thats the thing with servo's - you have to set an acceleration and top speed then tune the servo drive, it takes a fair bit of time to do each axis.
27-11-2016 #286
27-11-2016 #287
no, the corners are "dog-boned" or "T-boned" to get a square object in there.
maximum play is 0.04mm on any axis.
29-11-2016 #288
29-11-2016 #289
30-11-2016 #290
Just to clarify please, that the only difference between the Before and After results above was an increase in acceleration in motor tuning?
That's quite amazing!
P.S. Apologies that the first damn image (Attachment 19724) keeps appearing and then disappearing from automatic display!!!Last edited by AndyGuid; 30-11-2016 at 04:40 AM. Reason: Afraid the first damn image keeps appearing then disappearing from automatic display!!!
There are currently 12 users browsing this thread. (0 members and 12 guests)
Milling machine CNC conversion - keep hand wheels for manual operation?
By birchy in forum Milling Machines, Builds & ConversionsReplies: 5Last Post: 23-10-2016, 08:29 PM -
Manual autochanger problems.
By Saracen in forum Lathes, Lathe Rebuilding & ConversionsReplies: 1Last Post: 05-02-2015, 01:14 AM -
WANTED: Centec 2A manual
By Web Goblin in forum Items WantedReplies: 0Last Post: 03-09-2012, 09:56 AM -
Translating the manual
By Robin Hewitt in forum Moulding MachinesReplies: 22Last Post: 01-09-2012, 01:21 PM -
Bridgeport Conversion
By Tony Goodwin in forum Bridgeport Milling MachinesReplies: 0Last Post: 08-08-2011, 08:11 AM
