12-05-2016 #11
Good points, thanks.
By direct, I gather you have the screw nut coupled to the front where the depth-stop used to sit?
12-05-2016 #12
It's slippery slope and quickly your into it $$$ before too far to stop.!! . . . Don't Do it Listen to John S.
12-05-2016 #13
awww, bum, damn that cold hard logic JAZZ ;)
In my defence, it would pretty much fit in with exactly what i want though!
So, the alternatives then -
Find a donor machine and hopefully just fit the electrics?
Downsides I can see...
space - nowhere to put it.
would like a big table again - this seems to mean a big machine (see point above)
transport costs
unknown wear & tear
different tooling probably
This seems not too bad, but its bed is quite small, although it does have an ATC - would that be the sort of stuff to search for???
http://www.ebay.co.uk/itm/1821213470...%3AMEBIDX%3AITLast edited by Davek0974; 12-05-2016 at 06:08 PM.
12-05-2016 #14
Yep I'd take that every time over converting BP.
12-05-2016 #15
Hmm, looks like a no-go then - it weighs 4,500kg and has a 7.5kw spindle - i could not get that sort of power in the shop and anything much heavier than BP would be a bitch to get into place.
The bed is poor too - 500x600 not much bigger than my mini-mill!
12-05-2016 #16
12-05-2016 #17
That's the thing - I know mass rocks when it comes to machines, and also see the point of having a pre-ballscrewed donor but as you say - I need to be practical if I bother to do this.
It would have to be viewed as what it is - a computer controlled Bridgeport Knee Mill NOT a VMC wannabe. I really can't squeeze anything much bigger than a BP in and have no expansion options as we are residential so have to be careful a bit ;) There is no garden left to build a bigger shop.
In the past I have had bigger stuff - a Colchester Student lathe, a large horizontal mill and a vertical slotting machine - all the stuff i used when building traction engines for fun. Back then I would have killed for a CNC bridgeport but had neither the cash or the knowledge. Using a boring head to machine a 25mm hole out to 100mm and only being able to take small cuts gets old real fast - that job would be seconds with CNC ability.
I'm still not convinced and a bit pissed that the machine I linked to above costs less than the ballscrew kit alone :(
12-05-2016 #18
Why don't you trade your Bridgeport in for a Bridgeport interact and convert that to Mach3?
12-05-2016 #19
Something like this???
http://www.ebay.co.uk/itm/Bridgeport...sAAOSwYmZXD2Iq
13-05-2016 #20
Looks like a pretty good deal, I have used them before with the heidenhain control and they are good machines. Best wait for some advice from the others regarding suitability for Mach3 conversion.
Milling machine CNC conversion - keep hand wheels for manual operation?
By birchy in forum Milling Machines, Builds & ConversionsReplies: 5Last Post: 23-10-2016, 08:29 PM -
Manual autochanger problems.
By Saracen in forum Lathes, Lathe Rebuilding & ConversionsReplies: 1Last Post: 05-02-2015, 01:14 AM -
WANTED: Centec 2A manual
By Web Goblin in forum Items WantedReplies: 0Last Post: 03-09-2012, 09:56 AM -
Translating the manual
By Robin Hewitt in forum Moulding MachinesReplies: 22Last Post: 01-09-2012, 01:21 PM -
Bridgeport Conversion
By Tony Goodwin in forum Bridgeport Milling MachinesReplies: 0Last Post: 08-08-2011, 08:11 AM
