03-06-2016 #91
They're stockists for the Bijur range so should be :)
One of the (many) things I've still to do is finish off the control/safety circuits...I've forgotten what I was going to do so probably going to start from scratch again and try to get my head round the subject (I hate electrickery stuff!!) again :) The CSMIO products are good, I'm glad I went with them.
03-06-2016 #92
Let me expand...
I will have two Mach profiles - std Bridgeport & engraving
In profile 1 I have say output 7 defined as active low and no other connection
In profile 2 I have say output 8 defined as active low and no other connection
On the CSMIO each one of these outputs controls a respective VFD these outputs, being active low will come on as soon as Mach has started up and will stay on regardless of Mach reset condition.
So to do engraving I would fit the aux spindle and tell Mach to use profile 2 and so on.
It doesn't actually decide what to do, it just chooses the correct VFD for the profile I click on.Last edited by Davek0974; 03-06-2016 at 12:08 PM.
03-06-2016 #93
03-06-2016 #94
03-06-2016 #95I am doing something similar but with linuxcnc and mesa combo 5i25 + 7i76 so that one profile controls the lathe and the other the mill with one control boxI will have two Mach profiles - std Bridgeport & engraving..Clive
03-06-2016 #96
Sounds good, two machines with one system does seem to make sense when most of the I/O is the same.
04-06-2016 #97
05-06-2016 #98
Looking lovely Dave, looks so much nicer cleaned up and painted, should turn out to be a nice conversion/restoration.
.MeLee
05-06-2016 #99
05-06-2016 #100
Looking good Dave, are you fitting new ballscrews you ordered as you re assemble or are they fairly easy to access/fit without breaking down the whole thing again?
Milling machine CNC conversion - keep hand wheels for manual operation?
By birchy in forum Milling Machines, Builds & ConversionsReplies: 5Last Post: 23-10-2016, 08:29 PM -
Manual autochanger problems.
By Saracen in forum Lathes, Lathe Rebuilding & ConversionsReplies: 1Last Post: 05-02-2015, 01:14 AM -
WANTED: Centec 2A manual
By Web Goblin in forum Items WantedReplies: 0Last Post: 03-09-2012, 09:56 AM -
Translating the manual
By Robin Hewitt in forum Moulding MachinesReplies: 22Last Post: 01-09-2012, 01:21 PM -
Bridgeport Conversion
By Tony Goodwin in forum Bridgeport Milling MachinesReplies: 0Last Post: 08-08-2011, 08:11 AM
