Page 12 of 42 FirstFirst ... 2101112131422 ... LastLast
  1. #111
    These would be ball bearing races so not repairable in that way.
  2. #112
    Ain't a ball screw a ball bearing that could rotate as high as 3000rpm?
    I'm losing the plot here Boyan, I'm talking about the bearings inside the 1-1/2Hp spindle drive motor are buggered. ;)
  4. #114
    Drop-plates for X & Y servo motors - 10mm, 12mm, 15mm thick ally??
  5. #115
    Lives in East Lothian, United Kingdom. Last Activity: 22 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,984. Received thanks 369 times, giving thanks to others 9 times.
    Thicker will be better, but it will depend on servo shaft length/pulley thickness as to what's practical. Some form of box section would be better/stiffer.
    Regarding the motor bearings, unless the motor has some odd wiring/end cap configuration and/or you damage the windings trying to lever the end caps off, stripping it and replacing the bearings shouldn't be a problem.
  6. #116
    I was saying if it works for removing ball screw backslash and the ball screw is in fact a more complex ball bearing , its worth a try at the cheap price of it. How fast this motor moves? 1200rpm? Same as ball screw.
    I see as a better idea changing to cheap Dc motor or better servo motor. And why not a cheap modern normal motor , disassemble, weld some shaft and machine it on place. That would be super simple. And a bracket adaptor
    I'm going to have a go at dismantling i think, try that first.
    A 2.0kw AC servo would be best but a toss-up between money and easy-fit;)
  8. #118
    Well, I spent a good few hours trying to dismantle this motor while being very careful not to risk damage, I could not even get the drive disc off the long shaft, seized well on. There is also a pressed-on fan at the top to shift which would likely bend/break so i carefully replaced what i had done and left it.
    So my choice is now to build the cabinet and wire for the VFD / motor OR throw one of these in...
    http://www.aliexpress.com/store/prod...037588952.html
    I have asked the guy for a 2kw or 2.2kw 3000rpm unit but not had a reply yet, seems the bigger servos don't have the speed needed.
    Fitting would be easy, but the only benefit i would really see is the easy and accurate speed control - I don't need/want rigid tapping although i think it would be useful for smaller taps maybe - what is needed to gain rigid tapping?? Is it just a setup option or do i need more CSMIO modules??
  9. #119
    Pulleys/belt - 44t HTD8 x 30mm should handle it ok.
  10. #120
    You'd need an ENC module if you wanted to do rigid tapping.
    The motor will most likely run for a long time before the bearings get bad enough to cause issues. If you could get some fresh grease into them, it would most likely make them last even longer and quieten them down.
  2. Manual autochanger problems.
    Last Post: 05-02-2015, 01:14 AM
  3. WANTED: Centec 2A manual
    By Web Goblin in forum Items Wanted
    Last Post: 03-09-2012, 09:56 AM
  4. Translating the manual
    By Robin Hewitt in forum Moulding Machines
    Last Post: 01-09-2012, 01:21 PM
  5. Bridgeport Conversion
