14-08-2016 #181
Bravo!
.MeLee
20-08-2016 #182
22-08-2016 #183
23-08-2016 #184
The Following User Says Thank You to Boyan Silyavski For This Useful Post:
28-08-2016 #185
28-08-2016 #186
Very nice Dave and pro.
28-08-2016 #187
Looking great. Did you buy the blank tag material already made up or did you have to stick layers together? Can you let me know what the material is and where you got it? Thanks
28-08-2016 #188
I got it from here https://hindleys.com/index.php/ Its 1.5mm black-white-black engraving plastic, 600x300 sheet, £14 delivered.
First time i've used it and came out perfect, used a 30deg engraving tool, 0.2mm tip, 24000rpm, 900mm/min, air blast only and used an Aspire V-Carve path. Outer edges were cut with a 2mm single flute carbide bit with 6mm x 0.6mm tabs.
29-08-2016 #189
29-08-2016 #190
I'm going to need some of that plastic soon - good to see a source of smaller pieces at not-too-unreasonable prices. An 8x4 sheet would last me quite a long time...
Milling machine CNC conversion - keep hand wheels for manual operation?
By birchy in forum Milling Machines, Builds & ConversionsReplies: 5Last Post: 23-10-2016, 08:29 PM -
Manual autochanger problems.
By Saracen in forum Lathes, Lathe Rebuilding & ConversionsReplies: 1Last Post: 05-02-2015, 01:14 AM -
WANTED: Centec 2A manual
By Web Goblin in forum Items WantedReplies: 0Last Post: 03-09-2012, 09:56 AM -
Translating the manual
By Robin Hewitt in forum Moulding MachinesReplies: 22Last Post: 01-09-2012, 01:21 PM -
Bridgeport Conversion
By Tony Goodwin in forum Bridgeport Milling MachinesReplies: 0Last Post: 08-08-2011, 08:11 AM
