Page 32 of 42 FirstFirst ... 223031323334 ... LastLast
  1. #311
    Chaz's Avatar
    Page 39 of the current CS Labs IP-A manual .....
  2. #312
    Thanks, I use a supply line e-stop Pilz safety relay and main contactor and safety circuit, its totally separate from the controller for extra safety. It kills power to all drives and the spindle in use but leaves the controller and PC active.
    Its running now though.
  3. #313
    Chaz's Avatar
    Problem is that the drives will creep unless you can find the bias sweet spot on the drives.
  4. #314
    All drives now steady and happy. :)
    Just takes a bit of fiddling in setup
    Gone for a relaxed speed - no point in thrashing the bevels etc.
    Did an auto-set on the steps per, preliminary accuracy tests seem to show repeatability of -0/+0.02mm which think is pretty good for an uncompensated heavy knee. I could only test over 50mm as thats all my DTI will do so no idea yet what a long shift will do but most tools are within 100mm of each other so shouldn't be an issue i think.
    Can move on to macro tweaking now.
  5. #315
    M6Start macro sorted, it works really well using measuring tools instead of real tools, I'll give it a go on a real job at the weekend once i've finished testing etc.
    Its a most impressive add-on, she now has 350mm of clearance on the bed :)
  6. #316
    Chaz's Avatar
    Congrats, any vids?
  7. #317
    Thanks, hope to get a vid or two at the weekend - evenings are just too short :)
    Just need to iron out a bug in the index homing, might be noise from the rough lash-up i'm using or may need to move the home switch a little.
  8. #318
    Congrats, any vids?
    Here you go - bit rough as hard to video while pushing buttons :)
    https://youtu.be/npuQk2Ao7UY
    Also tested my homing accuracy...
    https://youtu.be/55VjHRgzt9s
    https://youtu.be/SUt1NiHZYIg
    https://youtu.be/fLXJXyGhipw
    https://youtu.be/sGrpzJVhkSk
    Can't ask for better i think :)
  9. #319
    Chaz's Avatar
    Nice, do you have a high speed spindle fit to the machine too? If so, any pics of the mounting please? I have a friend that will be interested to do the same.
  10. #320
    Here you go...
    http://www.machsupport.com/forum/ind...32513.500.html
  2. Manual autochanger problems.
    Last Post: 05-02-2015, 01:14 AM
  3. WANTED: Centec 2A manual
    By Web Goblin in forum Items Wanted
    Last Post: 03-09-2012, 09:56 AM
  4. Translating the manual
    By Robin Hewitt in forum Moulding Machines
    Last Post: 01-09-2012, 01:21 PM
  5. Bridgeport Conversion
