    Chaz's Avatar
    Lives in Ickenham, West London, United Kingdom. Last Activity: 4 Weeks Ago Has a total post count of 1,657. Received thanks 115 times, giving thanks to others 71 times.
    I would say if it's been fitted with servos and a CNC controller from new, it's got to be a good candidate. Could be worn out of course but a lot of the work will have been done for you even then. If you spot one of these with an old controller, it may be a good price and not hard to update. The X and Y servos (and belt drive covers) are easy to spot. If it's only 2 axis, you can do the Z axis yourself.
    Thanks, have seen a DIY solution for Z where the machines are 2 axis only. One of these (bridgeport or clone), worth looking at then?
    Ive got Thor for aluminium but would like something for steels or larger work area.
    Muzzer's Avatar
    Lives in Lytham St. Annes, United Kingdom. Last Activity: 7 Hours Ago Has been a member for 8-9 years. Has a total post count of 489. Received thanks 81 times, giving thanks to others 27 times.
    Generally on a quill machine the Z axis is done by driving the quill through a yoke attached where the feed stop used to be.
    Have a look at what I've been doing - some CAD models here https://mightyshiz.blogspot.com/2018...on-z-axis.html
    Chaz's Avatar
    Thanks, appreciate sharing this.
  2. Manual autochanger problems.
    Last Post: 05-02-2015, 01:14 AM
  3. WANTED: Centec 2A manual
    By Web Goblin in forum Items Wanted
    Last Post: 03-09-2012, 09:56 AM
  4. Translating the manual
    By Robin Hewitt in forum Moulding Machines
    Last Post: 01-09-2012, 01:21 PM
  5. Bridgeport Conversion
